Mercruiser 4.5l low vacuum, WOT 4350 and higher fuel consumption
damo79
MercNet, Dealer
Ha Ha, No longer a tech. Parts counter 18 hrs a week as my retirement hobby.
While I do have access to some confidential information, I only post things that I will freely give to customers that walk through the door.
Just please understand that we don’t help DIYer’s when we are busy with paying customers. That’s what this forum is for.
Do you know what was wrong with it back then? Was it repaired before auction or sold as it was?
damo79
@muc please see attached the recording of my previous checks. Idle, then steady plane at 3000, 4000 and WOT
  • MERC_CAN 07 28 2026 20 14 20.zip
muc
Only what found is vacuum pressure its 12in at idle and 0.5 at WOT. At 3000 7in and at 4000 3in. Correct at idle is 17-21. All sources on internet for 12in steady indicate problem with valves or timing chain. After season will take cover of and verify that.
The 12 inHg number you are worried about is from before the engine warm up state has completed. Unless you are troubleshooting a cold engine problem (you are not in this case) disregard all this info.
Once engine has completed warm up, you have about 17.6 inHg manifold pressure @ idle. Very normal number.
I'm guessing you might be getting confused about the manifold pressure numbers you see in Diacom. I'm not sure I can explain this properly (I'm not a very good teacher) but I will try.
If you hook up a mechanical vacuum gauge to a T that you install in the vacuum reference line to the fuel pressure regulator. Now KOEO and look at the gauge -- it will read zero, now look at Diacom -- it will read BARO and Manifold Pressure (MAP) as the same number, because the engine isn't running and there isn't any vacuum in the intake manifold. Now start the engine (KOER) and you will see BARO stay the same but MAP will read a lower number, now look at the gauge -- it will read the amount of vacuum in the manifold. If you want to check the accuracy of the gauge, take BARO and subtract MAP and you should get the gauge reading.
i.e. BARO 30 minus MAP 12 equals 18 inHg. Pretty high vacuum.
Does that make sense?
So a MAP reading of 0.5 @ WOT means there is almost no vacuum in the manifold.
So I think your barking up the wrong tree worrying about MAP numbers.
When you checked gear ratio did you disassemble and count teeth or count input shaft revolutions compared to prop shaft revolutions? In a situation like you have, I wouldn't trust the sticker on the side of the drive!
Also suggest you recheck fuel pressure how the manual recommends and report the all numbers to us.
muc
I took a second look and I'm not sure this was a warranty return. It was registered by the warranty department.
It was auctioned with a one year warranty, so Merc felt it would last at least one year.
So my guesses are, warranty return and repaired, engine used at a tech school or maybe a engine used for display at boat shows?
Thinking about it, probably not a warranty return because if Merc called it back from a dealer, it was probably a problem a dealer couldn't fix. Making it unlikely Merc could fix it for resale.
muc
I looked at it but there is only about 6 minutes of data after engine reached completed warm up state and during that time and you were changing RPMs to much to allow the engine to stabilize. So not any real usable data. It never reached full PID!
When making a recording for diagnosis.
Run around until engine reaches complete warm up.
Now back to idle and then increase RPMs in 500 RPM increments holding steady at each for 5 minutes.
Really need to reach full PID to get numbers that are usable.
I did note that your trim usage was very unusual. I saw very little trim usage and did see it go into trailer mode? Maybe you have a problem with the trim sender?
During recording use the trim normally.
I hate to comment too much on this recording --- because garbage in garbage out --- but you had some misfire numbers I've never seen before.
And water pressure looks a little low.
I'll be very interested to see a good recording and see if they are still there. Maybe post a pic of your prop.
What I did see looked OK
injector on times, spark advance, fuel trim, fuel flow and MAP.
What's missing is O2 numbers.
But like I said garbage in garbage out.
damo79
I will do it again tomorrow then and get some decent data.
When I did the recording you just reviewed noticed that engine was warmed up, got on plane waited for O2 status to change to closed loop and I was sure that it was the whole PID ongoing. What else to look for to be sure that its in full PID.
What do you mean by missing O2 numbers?
I agree that water pressure it should be higher. Not sure how it was before but few days ago got alarm 3-4 times with low pressure when started getting on plane. Checked it then in vessel view and it was like going up to 0.4-0.5bar up to 2000rpm and then when got on plane came below 0.05bar and that triggered alarm. Like mentioned 3-4 times and its fine since but low reading. Just before that I was refuelling in marina and saw lots of garbage in the water. My first thought was that probably plastic bag got suck in.
What do you think about this vaccum pressure at idle. 12-13"Hg its not normal. Checked manifold for leaks but found nothing.
Fun Times
What model stern drive is on the boat?
Is there a serial number on the drive itself and transom assembly too by chance?
damo79
Found screen shot from month ago and water pressure was much higher. It all changed that one day. Engine keeps right temperature maybe just pressure sensor is restricted. I would expect overheating if watter pressure is 1/5 of what it was few weeks ago.
damo79
I know what diacom shows in regards to MAP explained it to someone just like you did few days ago under post #18.
During Diacom test vacuum gauge was connected to manifold and never showed more than 12.5" on idle. BTW see attached. It's below 13"
Fun Times
It's alpha one gen 2.
1.62 ratio if I rememeber right
Yes, it seems time to open up the drive to replace the impeller and inspect other water flow components ...Post the serial when you get a chance.
It's no catalyst version.
Here should be your engine parts list, https://www.mercruiserparts.com/4-5l-mpi-250-alpha-bravo-2a441953-thru-2a530777
But, if possible, also post an overall photo of your engine as the catalyst statement seems sort of confusing.
Also post number 50 appears to be in need of editing as it's just a quote of Muc...
damo79
I will take engine photo tomorrow. It's version with only one O2 sensor per exhaust. I was getting confused with that mercruiser site with parts too. Its not very clear there with serial numbers etc. That sticker tells you all about catalyst - not for sale in California.
damo79
@muc when it comes to drive im pretty sure with correct ratio. I checked online Bayliner VR5 performance done by boating magazines and at 3000rpm and 4000rpm a get exactly the same speed as they did during boat test. If prop or gear ratio was different than what they had in test boat speed won't be the same at same rpm.
damo79
Props - turning point 14.25x21 and I thought that boat was sluggish because of that and replaced with SS 14.5x19.
As long i won't see correct vacuum pressure I will be barking under that tree 😉
damo79
@muc Checked manual and 45psi is correct fuel pressure for that engine.
muc
That chart is at idle. But you posted.
"Fuel pressure steady at 45psi - checked under load while on plane."
Under load should be about 5 psi higher. If you look about 30 pages deeper into the manual, you will find 50-54 psi with reference line removed. Removing the reference line will bring the reference side of the fuel pressure regulator to BARO, so basically the same as running under load.
muc
After 40 years of working on boats I don't trust those charts.
No mention of elevation.
No mention of ambient temperature
No mention of amount of weight in boat.
No mention of water/wave conditions.
All four of these variables can have a big impact.
You posted earlier that you're thinking about pulling the front cover to check valve timing?
To pull the cover, you have to pull the pan, to pull the pan you have to pull the engine, to pull the engine you have to pull the drive. Sure hope you check the ratio at that time ---- might save a lot of work.
muc
My bad! I missed that this ISN'T a cat engine.
Please disregard everything I said about PID, O2 and Misfires.
damo79
No way I thought its gonna be easier than that. Is it any other way to verify timing chain? IDK maybe measurement of valves and piston movement?
I will run Diacom tests today. Vacuum stays at 12.5"Hg reading on gauge with engine warm up that's I'm sure and I think I should focus on sorting that out first.
Not even sure what to look for - timing chain massive work, maybe valves or lifters. With correct compression what else could cause it?
Boat will stay in marina for another 2 weeks and then once on trailer I will check the drive.
And in regards to boat test. Sorry for just a screen shot. Link below. Its more and most are pretty much the same. I tested it in similar conditions.
damo79
@muc please see the attached Diacom recordings. The engine stopped due to an alarm, so the log is split into two files. Hope this is sufficient.
  • MERC_CAN 08 04 2026 18 27 04.zip
