Mercruiser 4.5l low vacuum, WOT 4350 and higher fuel consumption
nola mike
It does but too much imo. Vacuum is not shown directly. Vacuum is a difference between barometric pressure and manifold pressure. At WOT they both read nearly the same as you would expect but it's very low at 3000rpm when throttle demand is at 58.2% but arbitratted throttle position only 21.4.%. Got a feeling that engine is unable to create enough vacuum and PCM closing throttle to keep RPM steady.
Oh, gotcha. Looks like everybody was thinking that was relative/gauge value. Not sure what "arbitrated" TPS means? Is it drive by wire system? Also, looks like these values are at steady state conditions rather than WOT (otherwise demand should be 100% the whole time)? In other words, if you have it floored, does the TPS and demand both = 100% through the rpm range? When you hooked up a manual gauge, is that 13" steady? Lastly, your timing is (I think, LOL) going the wrong way. 29' at 3k, 19' at 4300.
Maybe I missed it but thus far i haven't noticed 12.9inHg in any of the screenshots...Saw 17.2 under Manifold pressure at idle of 6.22 RPM?
See his reply to me...those numbers are absolute manifold pressure.
damo79
damo79
Called arbitrated because that's probably average of two throttle sensors (TPS1 and 2 counts) but it general its percentage of throttle opening. It is drive by wire. I thought what whatever value of demand is should be achieved. Looks like engine is struggling to breath and PCM is doing everything to keep desired rpm. Spark advance it's going right way up to 3000rpm and then PCM delays it for some reason. My initial thought was timing chain - either slipped or came so lose or hang valves.
damo79
Maybe the new TMAP sensor changed the readings and hadn't really noticed it yet?
Yes, you can run with the vacuum line disconnected for a bit to test as that ought to raise the fuel pressure up roughly 5 psi on the pressure gauge and look for fuel leakages.
Looks like the boat is new to you?
Engine serial number sometimes helps when possible on your end.
New boat to me that's correct. See serial number on attached picture
nola mike
Why do you think it's struggling to breathe? If the throttle isn't opening all the way And the timing is retarded, that seems like something the PCM is doing on purpose. I'd like to see a graph of demand vs throttle opening at WOT throughout the rpm range. I didn't see any knock sensor data on there...
damo79
Because of low vacuum on idle. If its low on idle and its probably wrong throughout the rpm range. PCM control's throttle and timing. I will try to get graphs next time on water. There are no knock sensors on that engine.
Found something interesting but that general info for ecm555. Injection time can double for example for 3000rpm if vacuum is very low. See attached screen. That's what's happening in my case at 4000rpm there's nearly no vacuum so PCM uses correct multiplier and it burns 50% more than it should
jimmbo
Low vacuum, as well as an Inverted Vacuum curve, I would be inclined to think the Sensor that monitors it defective.
In Post #24 you said the Boat-motor was new to you, so you haven't got the repair History of it. I assume this below the WOT range of this motor, rpm you posted is how it has been running since you got it. What boat is this in/on, and what pitch are the Props you have tried on it?
damo79
MAP sensor is new and compared redings in Diacom with gauge connected to intake manifold. It works well. Its on Bayliner VR5. Bought it with 14.25x21 and now 14.5x19 is installed. With this setup it should rev to 5000-5200.
The VR5 with the 250hp came with a 19p prop
jimmbo
However since you don't know the Service-Repair History, what is the Gear Ratio of the Outdrive currently on the Hull?
What is the Manifold Vacuum at Idle, and at WOT, read from an actual Vacuum Gauge?
I know on my 5.7 it is 18" at Idle, and 4.5" at WOT with the 500cfm 2bbl, and with the 650cfm 4bbl, it was 1.5".
muc
This is a 2016 warranty return engine sold by MCM at auction in 2018.
Yes, check gear ratio. What you've posted so far looks to be over propped.
Fuel pressure looks low. Should be 50-54 psi with no vacuum on the regulator. Are you testing per the manual?
But we are looking at "snap shots" of .1 second readings. So not a lot of info there.
Might want to do a recording and post it.
Here is my recommendation on how to do the recording.
Start with a cold engine and the boat in the water.
1. Connect Diacom
2. Turn on batt switch, turn on key switch -- but don't start engine
3. Start Diacom recording -- let run for 30 seconds to one minute
4. Start engine
5. Check that Diacom is still recording, it's not uncommon for it to have lost communication during starting. If it did, save that recording and start another one.
6. Run the boat gently at idle to 1500 RPM until up to operating temp
7. Run the boat up to full speed --- take your time, looking to get data here so advance the throttle slowly (spend five to ten minutes) now slow back down to minimum wake and idle in neutral for awhile. Use the trim as you normally would.
8. Do a "ski start" -- full throttle all the way to full speed and trimmed out, now back to idle fairly quickly.
9. Drive boat back to the dock/ramp and shut off
10. Stop recording and name the files
damo79
I've been on it for weeks. Checked props, outdrive ratio, replaced gimbal bearing before summer, tried 2 props, even weighted boat to see if there is no extra load. Only what found is vacuum pressure its 12in at idle and 0.5 at WOT. At 3000 7in and at 4000 3in. Correct at idle is 17-21. All sources on internet for 12in steady indicate problem with valves or timing chain. After season will take cover of and verify that.
damo79
1. Connect Diacom
4. Start engine
What I've got is the recording of more or less what you pointed here, but i posted only snapshots. Will do another test anyways.
damo79
BTW where did you get that information about warranty return? Can I see the source please
muc
He's a merc tech, has access to super secret classified info (seriously)...
Ha Ha, No longer a tech. Parts counter 18 hrs a week as my retirement hobby.
While I do have access to some confidential information, I only post things that I will freely give to customers that walk through the door.
Just please understand that we don’t help DIYer’s when we are busy with paying customers. That’s what this forum is for.
jimmbo
There are a few more contributors on iboats that have access to MercNet. However, being it proprietary, they are limited to what they can openly reveal.
