Overheating Possibly Caused by Restricted Thermostat Housing Port
KM7
1991 Four Winns 200 with 5.8 L Ford V8 and OMC OD.
I was cruising the harbor on Sunday with friends and noticed overheating at the port exhaust elbow. The engine temp gauge was only slightly above the midpoint, so it was approximately 172 Deg F. The starboard elbow did not seem as hot.
I was expecting to find rusted and blocked passageways in the elbow, so I removed it. It was easy to do, remove 4 bolts and 2 hose clamps and the elbow, along with the round exhaust pipe comes out. See pictures
I think that I found a different cause. The hose from the thermostat housing to the exhaust manifold was very cloged and the outlet of the thermostat was rusted and had narrowed down to only about 1/4 of an inch.
Questions: As you can see on the picture. I have not seperated the elbow from the exhauts pipe. Any suggestions?
Has enyone tried cleaning out the rust with Evapo-Rust?
I'm considering that and replacing the hoses.
Below is a picture of the hose
KM7
Update 7/29
I was able to separate the round pipes from the elbow. A few hits with a rubber mallet was all it took
After looking at the elbows more closely and checking prices, I have decided to replace both elbows. I can get both with the gaskets for under $250
I will clean and repaint the round pipes. That way I will be sure that I get a good seal with the rubber hose between the pipes and the elbows.
I checked the Exhaust Seals and they are working fine. (item 51 on the Crowley Marine page)
KM7
Some of the gaskets between the exhaust manifold and the elbow have 4 wide open passageways for water. On some of the gaskets, 2 of the sides only have a hole for water flow and not the full area. Why is that?
Did OMC make a revision? Which gasket should I use? BTW, I am using new elbows, which should give very good water flow, and the exhaust manifolds should run cooler.
Lou C
I have that style exhaust on mine and I used the gaskets with the 4 open sections. That elbow that you posted a pic of was definitely in need of replacement given the level of clogging seen so that's a good choice.
With this job the issue is making sure that the sealing surfaces are flat and level, and that they are not pitted with rust. Leaks around those gaskets into a cylinder are quite common and cause a lot of damage. How do the cooling passages in the manifolds look? If they are as clogged as the elbow you posted I would at least try to rod them out.
The passages in the thermostat housing also get clogged/necked down over time you can rod them out with a coat hanger wire. That clogged cooling hose was probably the cause, what was clogging it? Might be able to re-use it if you can blast that crud out with a garden hose.
On my OMC 4.3 I did a 2 piece exhaust conversion about 9 years ago using Barr Marine exhaust parts with Volvo Penta 90* down pipes and hoses, it all fit perfect and no leaks. Probably have to replace the elbows at least this fall or next year. Saltwater use for me.
KM7
Lou, thanks, you have been a great resource for years. I have not been on since the gimbal bearing/ housing/ bellows repair a while ago. She has been running well.
The exhaust manifolds look better than the elbows but I will try to clean them out. I can prevent large pieces of rust from falling into the manifolds by stuffing a rag into them and then vacuuming them out, but I expect some debris will get past. Should I be concerned? How big are the passageways downstream?
I used a drill to open up the passageways in the Thermo housing for the hoses to the exhaust manifolds. Now that the thermo is out I'd also usind Blaster rust remover. I think the debris in the hose may have been the main cause. I did clean them out and will reuse them.
Mine is always in saltwater, Long Beach CA, I rinse after and run Salt Away.
Now I have to find elbows that use the gasket with 4 fully open passageways. It seems most have the one with the 2 small holes.
KM7
One of the suppliers says his fits a 5.7 but 19192 and on. My boat is a 92 but with a 91 motor:
Ford 351 Cu In Model 584APLRGD Serial No. T01224704
Did something change in 92?
Lou C
As far as the elbow fitment, I think there was an issue with the engines that had EFI, the elbow for the carbed engines wouldnt work for them probably because of some bracket for an ECU, not sure of other changes.
I'd look at marineengine.com and look at the Barr exhaust catalog. Those gaskets should be readily available.
About the manifolds, yeah you don't want any rust flakes falling in the center exhaust passage for sure. I would probably remove the manifolds to clean em out and re-deck that sealing surface (mill bastard file does a good job, rotary tools are a bit risky).
The other test you can do on the manifolds is the acetone test, fill the water passage with acetone with it propped up level (careful flammable) and see if the level drops in the ports over time, also look at the exhaust ports to see if there are any wet spots. If so then you need new manifolds. Expensive but it's unavoidable in salt water with cast iron exhaust.
Here's another thing that a lot of people miss that should be checked with a raw water cooled cast iron engine....the water passage in the intake manifold, these can rust through and put salt water in the engine oil, I have not had that problem yet but I check the bottom of that water passage every time I have the thermostat housing off. I tap it with an extension and a small hammer to make sure it "rings". If a dull thud it's on the way to rotting through. l have a spare Chevy V6 intake in the garage that I am cleaning up in case I need it. Not as familiar with the Ford intake so not sure if it's the same issue. But good to find out, because salt water in your oil is a BAD thing!
KM7
I'm cleaning the mounting surface on the top of the exhaust manifold where the gasket will be, and on the port side there is a very hard sealant or something. BTW, that is the side that was overheating. The sealer (?) is lime green and comes off with a lot of scraping. Could it be a filler used to repair the gasket surface? Maybe I should not be scraping it off!!! Any thoughts? I'm going to create a separate post just on that topic.
I have been using a shop vac to suck up any debris.
I was going to switch to a sanding block and sandpaper, but I will wait and see what you or others say first.
Lou C
Post up some pix. Might be something the previous owner did.
KM7
Here are pictures: The first one shows the green material. The next 2 show the manifolds after cleaning them up as best I could.
Lou C
Agreed I would not chance it, esp in salt water. Not enough left for the gasket to seal.
kenny nunez
2XS with BONDO. Those manifolds are going to cost you a new engine if you do not change them.Check out the price of a rebuilt Jasper or similar rebuild plus labor, freight and tax.
The way you are maintaining your engine it will out last the boat and the drive system. Ford engines are made from a better cast iron than GM.
There may be a smaller metered by pass opening it the thermostat housing. Try to clean all the slag out.
Lou C
PS:
24 years of salt water boating, here’s my experience:
the system I put on a in 2017 is the third exhaust system I have had on this boat. Changed the original Batwings in 2004, that set went to 2011, then installed another set of Batwings; when I had to change the cyl heads, gaskets etc in 2017 I converted to the later style OMC/Volvo exhaust. Never had water in a cyl because of bad exhaust. I say 7/8 years max in salt after that the chances of failure get a lot higher. Even if my manifolds look ok I’ll probably just replace the whole thing. $1,000 in parts and 2-3 hrs my time. Cheaper than a new engine!
KM7
I don't know what you mean by "2XS with bondo". Why would the manifolds cost me a new engine? I am planning on changing the Elbows/Risers. If I file the manifolds flat why wouldn't they seal?
I will look for a metered bypass hole for the thermostat, but how sure are you that there is one? Where do I look? I have been soaking it with rust remover, and I don't see a passageway yet.
Ayuh,..... That means they are agreeing with my post #12,.....
Running that manifold will cost you a new motor, because that manifold is rusted out,.... The gasket sealing surface is but a small part of a rotten manifold,... At some point, fairly soon, that manifold will dump raw water into the motor, 'n if running, a bent rod, or worse will be the result,.....
All that rust you're cleaning out of the manifold, 'n the t-stat housing, Used to be cast iron,.....
To save your motor, I'd replace the manifolds, 'n the t-stat housing,.....
They're long past just cleaning them up,......
Lou C
You will get salt water in a couple cylinders because there isn’t enough cast iron left for the gasket to seal. Look at the pic that I posted of a new one, the sealing surface is much wider. Like 3/8ths” to 1/4” wide. So it will either rust up exhaust valves if a small amount of water or hydro lock a cyl if a large amount of water. Most mechanics here will say replace both by 7-8 years.
