Force 2 cylinder throttle cable adustments
metalchewy
Trying to figure out throttle cable adjustments on a 1990 Force 50.
When put in forward gear, it engages the drive, but can move the throttle forward about 30 degrees before it the throttle cam (#2) starts to move. Can't get full throttle.
#4 was backed out 1/4", but not sure if that's the issue. Looks like it engages forward drive.
#3 looks like cable adjustment
#1 looks like throttle cam adjustment.
I can't find any kind of technical service manual for this, to get the proper procedure. I am hoping someone on here can provide some insight.
Many thanks in advance.
Nordin
The connector for the throttle is spring loaded (#3).
The purpose of this is that the gear shifter will engage the gear fully before the throttle starts to move.
The adjustment of the throttle connector is that the spring has to move about 1/4 in to fit into the ball connector.
Then adjust the throttle rod (#1) soo the throttle butterfly is horizontal when remote control is fully forward.
Then adjust the idle screw at the timing tower.
First before this adjustment you have to check that the throttle pick up point (#2) is okey.
metalchewy
Thank You @Nordin .
I didn't adjust the throttle connector at all. It's as it was when we took the outboard and linkage off the donor boat. Just reinstalled it as it was.
The throttle pickup point has line on it. I assumed throttle rod should be adjusted so the plastic roller bushing starts at that line. ( The roller is fine, no grooves or cracks in it.)
When I adjust the throttle rod to get the butterflies horizontal, that line is 1/2 inch below the roller.
In testing in the water barrel, it raises the idle a bit when I start it, but starts fine. Re-adjusted idle mixture for the new speed.
Will give it a test this Saturday morning and see how it goes on the lake.
Curious if I should adjust anything on the shifter control side? It's a US Marine control that came off the bayliner.
Nordin
The scribed line at the throttle cam is the throttle pick up point.
You adjust the throttle pick up point by losing the throttle rod from the ball at either the cam or the timing tower. Be careful when losing the rod from the ball, it can break the plastic connector.
The roller i mounted with a screw with a locking nut and it is eccentric.
You loose the nut a little and the turn the screw soo the roller intersect the line when it touch the cam.
Fasten the roller in that position by the nut.
Now the throttle pick up point is adjusted.
The roller will be above the line when you have adjusted the idle, it is just normal.
You adjust the idle by the screw at the timing tower, the mixture screw at the carb is a air/fuel mixture screw.
It should general be 1-1 1/2 turned out from lightly seated.
Do not adjust it less than 1 turn out, the idle can be better with it less than 1 turn out.
BUT the mixture at WOT can be to lean and you can melt a piston.
This screw is for low speed, but on these Walbro or Tillotson carbs it act at high speed too.
jimmbo
Almost all of, if not all of, the Timing Advance happens before the Carb begins to open.
With the Control Cables unhooked, does the linkage move enough to fully open the Carb?
metalchewy
@jimmbo and @Nordin Thank you both for the additional responses.
With the linkage unhooked, yes the moves enough to open past horizontal on the inner butterfly.
After adjusting the throttle rod (which was way off at 3/4 open) and only leaving the throttle linkage hooked up it is now horizontal at wide open.
The lower cable for the timing seems to not advance the timing to max. Like 1/4 inch from max. I assume I should adjust it to hit max on the timing?
jimmbo
Okay, now that you have adjusted the Linkages, it is time to get the Official Service Manual for your Engine, and do a Link and Sync to get it all back to where it should be.
Nordin
metalchewy, lower cable for timing!!!!!!!
The lower cable (your pic in previous post) is the shift cable!
The upper cable is for the throttle.
On these Force engines you set the timing at WOT.
You can do it in two ways, static or dynamic.
The dynamic give you the correct timing BUT you have to do it with running the boat in water.
Static you do it in the drive way or at at stand.
Factory spec is 32 dgr BTDC at WOT, but I would suggest you to set it at 30 dgr, it will make the engine to last longer and engine will "feel better".
When setting static you set the timing by 28dgr BTDC with a timing light and turn the engine over with the starter.
Set the throttle at WOT and run the starter, use the timing light at top plug and point it at the flywheel, check where the light flashes.
You change the timing by shorten or lengthen the timing rod.
28dgr static will end up with about 30dgr BTDC dynamic.
metalchewy
Agreed. Thanks. I have a hard copy on order and it should be here Friday.
Thank You!
Ok, will just put the lower linkage back on where it sits. Shift in and out of gear was working fine.
Will check the timing static, and make sure it is around 28. If it's not will put I in the barrel and adjust it to 30 while running before we take it out Sunday.
Nordin
metalchewy, the dynamic setting has to be under load.
If you will adjust the timing in a barrel you have to have a test propeller.
Hard to find and not worth the cost if you find one.
Set the timing by static and leave it there.
I always set it static when I do it, I also check the timing by running the starter and use a timing light.
metalchewy
Ok. Thanks for the clarification. Will put my spare timing light into the dry bag. Going out Saturday morning.
When you say under load, is that just in gear and idling, or faster?
Nordin
As I mention earlier you set the timing at WOT (Wide Open Throttle).
That is why I do not set it dynamic, you have to be at least two in the boat.
28dgr static running with the starter 250-300 RPM will end up at about 30dgr dynamic at WOT, one degree more or less does not matter.
jimmbo
Hanging over the transom above a Flywheel spinning over 4500rpm, is not my idea of a good time, especially if the Water, isn't like Glass
metalchewy
:LOL::LOL:
Agree, wide open throttle on a lake sounds like the person standing in the back (which would be me) wouldnt enjoy...
Static at 28 sounds way better.
metalchewy
Throttle worged as expected on Saturday. Thanks all for the hekp with it.
The manual says something about a warmup button the control box. I donh have such a thing on mine. Is there a way to rig one up, or would that require a different controller?
Nordin
How does your remote control look like?
Pics if you can post.
Almost every remote control have a warm up function, only different way to use it.
If you have a Chrysler remote control there is a knob that you pull out to engage the warm up function.
US Marine remote have a button at the center of the handle that you push in to engage warm up.
Other remote controls can have a separate warm up lever, some remotes you pull out the whole handle.
There are many different ways to engage the warm up function depending on what remote brand you have.
Some pics will help to identify the way.
metalchewy
Its a US Marine controller, out of the 1990 bayliner capri. I didn't seem to get pictures of it outside the box we built to mount it.
I did get pics of the repair I made to fix the broken pull to put it in gear. Jbwelded some stainless mesh on the outside and stainless pins on the inside to keep it from breaking off again.
I Checked ebay and found these pics that are exactly like the controller.
Screenshot_20260729_185046_DuckDuckGo.jpgScreenshot_20260729_185137_DuckDuckGo.jpgScreenshot_20260729_185101_DuckDuckGo.jpg
That plastic square In the base, just clips in to reveal the screw to remove the handle.
Nordin
As it says on the handle you pull the handle out and then push the the handle forward.
When pulling the handle out you disengage the gear and only the throttle being activated when pushing the handle forward.
metalchewy
Tried pulling it up last night and it wouldn't budge. Will try again tonight after work.
