Late 70's to Late 80's - Worth shopping for?
Berdink
I go back to AutoZone to return it with my newfound knowledge that some compression testers are bunk. I'm telling the young fella this.
He wasn't interested. 😊
Berdink
I'm off to do a forum search.
I know the big red plugs go together. But for the smaller plug there is 5 wires. Blue, Green, and Red - all with a white stripe. I'm thinking those are for the Trim.
But what are the white and black wires for?
The black wire has a white or grey stripe, and the white wire has a brownish tan/gold stripe.
Berdink
Google says:
"On a Johnson/Evinrude outboard, a 5-wire harness featuring green, blue, red, white, and black wires corresponds to your Power Trim/Tilt System inside the control handle."
I understand the green red and blue being for trim. I just don't see what the black wire and wire is for.
There isn't any corresponding plug on the motor that matches that matches the plug coming from the controller. As it is now, the Tilt Trim is a button on the side of the housing.
Berdink
My controls appear to be from an older motor.
Berdink
I found what the white wire with the brown stripe is:
"White with Light Brown Stripe: Trim sender (runs to the trim gauge"
Berdink
And I found:
"Many older OMC control boxes come with a small accessory wiring harness to supply connections for dash gauges.
Gray: Tachometer signal wire (connects directly to the tachometer "S" terminal).
Purple: Supplies positive 12V to gauge lights and instruments when the key is on.
Black: Ground wire for the gauges"
redneck joe
I would recommend starting a new thread on this engine specific. you have four pages of non related stuff. Start fresh.
Berdink
I do want to apologize for being slow on the uptake for best practices for this forum.
I'm going to try to follow this Google Ai Answer:
"The iboats forum strongly prefers that you create a separate thread for each individual issue.
The moderators and community prefer this structure for a few reasons:
Clearer Troubleshooting: Mixing different issues (e.g., electrical problems and a carburetor issue) in one thread gets confusing very quickly as multiple members try to reply to different problems simultaneously.
Accurate Titles: A separate thread allows you to use a hyper-specific title for that exact problem, which makes it much easier for other users with the same issue to find your thread in search results.
Easier Organization: Moderators often move off-topic questions or separate distinct issues into their own threads anyway.
Posting Best Practices on iboats:
One problem, one thread: Keep all questions and updates regarding one specific issue inside just that single thread.
Post in the right category:
Post your motor questions in the engine category, and hull questions in the boat restoration/repair category, so the right experts can help you. You can browse the categories on the iboats Boating Forums page.
Include your specs: Always state your exact boat year, make, model, and engine type right in the first post so members can give you accurate advice."
Berdink
Just a side thought.
I'm turning wrenches on this.
I'm going to clean the carbs. I have a separate thread for that.
But as I begin, coming from a Suzuki and Yamaha, it feels kinda nostalgic to be using standard wrenches.
My old 65 Chevy gave me that feeling. And I can just eyeball the size I need. 😊
Berdink
If the V4's are prone to break piston rings, then it sounds like they aren't worth shopping for.
The late 70 / 80's model 3 / 4 cylinder OMC are excellent.----Pick one up for $500 or less to rebuild.----You would no longer worry about $100+ / hr shop support or $10,000 + for a new motor.
Why didn't you mention the common breaking ring issue here?
Have seen lots of videos by " vintage boats "-----Talks about chrome plated cylinders on 15 HP Johnson.----Fact is they never ever had that feature !-----Lots of false information by this presenter.----And if you do not know you would believe 100% of the presentation.
Have had compliments on rebuilt V-4 models.----" Have had it 5 years and never missed a beat "-----Or " you rebuilt it 12 years ago, still runs like the day we got it "------Wiseco O/S pistons with proper shaped piston rings.
Berdink
If/when, yes.
