Battery switch only for motor circuit?
infx708
I bought a 2019 Four Winns HD200 OB. It has two batteries, one for the motor and one for everything else. There is one battery switch and it only controls the motor circuit. Does the, I'll call it hull circuit, not need a cutoff switch? Is that function supposed to be served by the ignition switch? I can't find a wiring diagram.
dingbat
The "hull circuit" (house) is typically feed thru the "accessories" connection on the back of the battery switch.
infx708
Ok. I took a closer look at things and it looks like the batteries are connected in series, but have the swithc between them. Not knowing the internal wiring, I can't really say much more about it. I do know that with the switch off, I can turn the ignition switch and the dash and gauges come to life.
alldodge
If it's in series it means there is 24V potential. The motor and gauges should only have 12V not 24V. Do you have a trolling motor?
Post a pic
dingbat
It’s not supposed to do that. Off means off….
Basic wiring diagram
infx708
The large cables are set up like this, but there are a couple of smaller cables that are connected to both posts on one of the two batteries. I can't really trace them right now. I just found it really odd.
JASinIL2006
Sometimes people will wire certain things to the battery directly, like an automatic bilge pump or a radio/stereo (to preserve station presets).
jlh3rd
I have a 2 battery setup on my pontoon.
"OFF" is off. Ignition/key switch has no power.
I don't have a bilge so don't need a hot wired pump.
