115 6c TOP piston cylinder issue
ianmoore
While you have it apart, check the swivel pin for binding. If those two bushings get corroded the motor will be hard to steer, and if it is all together, you will hate yourself. Ditto on the top and bottom rubber motor mounts.
See if you can thru drill the broken water cylinder head water jacket cover. The old IL motors (early 70s) had thru holes and nuts. My '77 water jacket cover bolts were tapped, but you could drill thru the casting on the upper ones and put a nut on it, as the casting had a "pocket" for it.
I'm gonna look into the swivel pin and that area. I had to take the whole motor apart because the trim motor was completely corroded. I'm having to peel it off to try to salvage the pump, which i think is good. the lip at the top of the pump housing is a little nicked, but the orings and the mating surface inside seem good. I'm gonna see if I can salvage that and if not, gonna buy a pump and motor.
Ive already commited to getting a time cert. I looked at the back side for a nut and it was pretty tight to get anything in there.
No, bleed inserts are small black plastic restrictors that fit under the transfer covers. At least I think they go under the transfer covers. It has been a long time since I looked at an IL6. Number 3 in this diagram. They help with idle quality
ianmoore
Thanks! Those are really confusing!
I can’t tell if there is anything in there or if mercury built it into the body. If there were inserts within these cavities, they were teeny!
Five the the holes should be the same size. The 6th hole will be larger, since it has no insert. I would say you have white plastic inserts in the pictures provided.
There are 5 bleed inserts.-----In the past I installed 8-32 set screws with 0.040" hole.----Never to fall out again.
ianmoore
Chris. The swivel pin is actually pretty smooth. I have kept the zirc fitting full and it actually feels good. Is it just the retaining ring to remove the pin?
I looked through all the parts diagrams to look for rubber motor mounts. Are you referring to these: 1783002013863.png
Mine are pretty toasted, if so. I'm trying to figure out a few things. I would have to cut these bolts out and then rebuild. The rubber piece is $60 retail and not seeing a ton much cheaper on ebay. I want to do the things that matter on the motor, so will take the time to do it if it does. Wanted to see your thoughts. I have some pretty rusted/deformed bolts on this whole section. Trying to figure out what to do as Ive had a heck of a time with a couple of bolt removals(salt). I couldn't even reverse drill them out. I have a portable drill press, but its hard to get a good level for drilling on some of these partsIMG_6568.JPG
ianmoore
I need a magnifying glass! They look like metal to me, but i can't imagine putting anything smaller in there, so either they are built in or are still there
Sierra used to make motor mounts. They were all rubber, vs the rubber and metal of the OEM stuff. I used them and they were fine. They were about $50 ea.
The top motor mount bolts were grade 7, 9/16 fine thread if I remember correctly. I had to cut them, as the motor mounts could not be removed from the bolts due to corrosion, so both needed to be new. The lower motor mount bolts were grade 7, 1/2" fine thread.
If the motor mounts do not have play, leave them be.
That rusty bolt above the yoke was a "U" shaped piece of steel. I guess it was to hold the swivel pin, if the lower mounts broke.
ianmoore
I think I'm gonna replace them. I'm trying to figure out on the swivel bracket which parts I need to get that I can't get locally. Seems like just the two bushings. To get to the swivel pin, you just need to remove the retaining pin on the bottom?
There is a springy retaining ring under the bottom yoke. To remove the swivel pin, you would have to remove the upper motor mounts, by splitting the exhaust extension. You can leave the yoke attached to the motor mounts and pull the swivel pin up and out, after removing the retaining ring. Check the yoke for looseness on the swivel pin splines.
Upon further (mental) review, I think my '73 had a nut under the yoke. My '93 had a retaining ring. Not sure what '77 had. Not sure what you have.
ianmoore
I can see a retaining ring.
It seems that to remove the upper bushings I could cut the nut and pull back but maybe the screw wouldn’t pull out. I’m realizing I’m probably gonna have to drill out the 5 bolts to the middle exhaust. They are so corroded and there is no way other than that to get them outIMG_6606 Medium.jpeg
ianmoore
Interesting. I’ve been working on the crankshaft. It looks pretty good( cleaned up a bit of grit on one bearing-now smooth) and noticed the alternating 5 petal, 4 petal arrangement. Nothing mentions this. Is this something Mercury did?
I have a couple of petals that are more than the .007(closer to .011). Someone mentioned that not being an issue.
First- is this normal or did someone change something? The 4 petal side doesn’t have an opening. But on all the sites it lists the 5 petal as the 90 and the 4 as the 115.
I have some 5 petals I was gonna replace the out of spec reeds with. Should I order 4 petals too?
Gee, not sure on the 5 nuts. on my '77 and '93 Mercs, I had to cut the upper motor mount bolts and replace the motor mounts and bolts. 7/16 grade 7 I think. Best to check it out.
I would let the reeds lie. it is at idle is when they act up. So if a good idle means god reed valves.
ianmoore
My idle is a little high. When I first got the motor and was getting to know it I was told that was “just how it was” with old Mercs and the trade off was biting the gears a bit. I could never get it much below 950.
My attitude is since it’s all apart, I should replace what I can. That stuff really isn’t that big I deal.
These inline 6 motors run very nice / slow when in good condition.-----Folks often start guessing / adjusting things.----They mess them all up.
ianmoore
When i first got it I had never messed with a motor before, so everything, including adjusting the timing, is a bit suspect. I think i got it right, and i followed the manual..The engine ran well, but it was hard starting cold, and i had i set the idle screw a bit hot for it to idle well. I got it where it ran well, and it ran great for about 8 years, until the end of last year.
I'm still a bit confused as to what happened with the cylinders. From what I've read, i would have known if I'd lost one. I was noticing last year that my top end RPMS were down below 5k, and it did bog down a bit when i would holeshot. I figured at the time i just needed to do some work on the carbs and/or fuel system..
To address Racer's comment. I had a 1500 for a couple of decades. I found that if the carbs and throttle cables were adjusted for the proper idle speed and acceleration, and the fuel mixture was a fresh 50::1, the engine would idle pretty good, say several minutes w/o stalling. Also, as long as you ran the motor on fresh 50::1 it still idled pretty good. After a week, the fuel would be a bit rich on oil, and the idle would degrade from idle for a minute or more, to idle for 30 sec and then stall.
ianmoore
quick question:
I have built my pistons and started installing them. I had 4 of them in(waiting for rings for 2 pistons) and was checking through exhaust ports. All 4 seemed to have the same up and down feel, and the rings seemed tight in the ring lands.
I had a note to check the ring stops to make sure rings were lined up. I was looking a piston 2 and saw one side and was turning piston to see other ring stop. I hit a bit of resistance, spun it back and the ring that i had just looked at was broken.
It is possible that the ring had a crack or some defect(most of these are new old stock) but i want to make sure i didn't break it by inspecting it.
should you spin pistons around to check for the ring stop or is it enough to feel smooth movement of piston and see rings sitting smoothly in ring land?
ianmoore
Wow. That is a sensitive engine! I'm assuming you had it down at 650-700? I was told you had to keep your idle a little hotter.
I am pretty good with the non-ethanol gas and using Marine stabil when its sitting, but here in the puget sound, with not many fuel docks, it is hard to be that on top of it with new fuel all the time
