Need A Metallurgist's Advice
JimS123
Picked up a 1945 Neptune outboard at a garage sale. The PO bent the tabs on the bottom of the gas tank for whatever reason. The tabs are to support the motor when set down.
I have an idea how to bend them back straight again, but I thought I would see what y'all have to say. I'm afraid that it might just crack in two.
The pics below are the problem motor next to a restored one showing what it should look like.
Jeff J
I’m not a metallurgist but from experience I would say aluminum will break and steel might break. A good welder could repair them if they break.
bajaman123
Heat is your friend, but make sure that fuel tank is completely empty of gasoline if you do so and fill it up with water prior to using your heat wrench.
You will want to heat them to about 500-550 degrees to bend them. Go slow
I would recommend a heat putty to prevent the rest of the casting from getting warm
JimS123
Would a hand held propane torch be adequate?
The bars are aluminum.
dingbat
Most aluminum alloys are not readily bendable with heat or no heat due to its crystalline structure.
Since it’s bent, we know that it’s a 5XXX series aluminum which is highly mailable, ie readily bendable w/o heat
Aluminum is cold worked since heating aluminum is detrimental to corrosion resistance of the material.
5000 series aluminum is an extruded / rolled product vs a cast product. Most likely A356 or A380
The anneal point of the casting will be about 570F
A temp stick will be your friend when applying heat
Make something to slide over them as is?----Small rubber hose followed by bigger rubber hose as an example.
Or use the IR thermometer that everyone that services their own boat should have
dingbat
Good AI answer….lol
Guess AI hasn't been in the metals industry as long as I have..,,,,lol
Pure aluminum is smelted with other elements to create the alloy. The finished material is then poured into billets or slab depending on the end product. Material destined for sheet products is in slab form.
The slab (up to 30+” thick) is then broken down either in the roughing mill or scalper before going to the finishing mills then coiled.
From there it goes to the various process mills for final reduction, surface treatment, annealing and leveling before being wrapped for shipment.
Been dealing with castings and aluminum extrusions for years. 5052 is what most tinnys are made out of
Now there are 5xx casting alloys like 514
JimS123
Thanks to all for your replies. The boat is ready to sail so this oldie will be a Winter project. I'll reply with the results when I do it.
dingbat
Did some work on bronze and aluminum casting designs back in the day.
Welcome to my world.....lol
At 2:23 one of our measurement devices is front and center on the screen when they give us a shout out......"characterized by close thickness tolerances"...lol
Texasmark
We worked with a lot of 5052 T6 aluminum sheets when I was in industry. No castings, just sheet goods.....don't know the aluminum material type on castings used.
