1997 Mirrocraft 18' aluminum fish n ski
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
No idea, but think it should be easy to test. Although doing it with earmuffs might not provide enough water/pressure.
SHSU
BWR1953
SHSU
Good point about the muffs. I'll be sure to use a barrel for testing.
BWR1953
My buddy came over this evening and got the steering hooked up again. Next step for me is to get the boat out of the garage so that I can get it cleaned and cleared. I'm going to trash a bunch, donate a bunch, then get everything organized.
The boat will sit in the yard covered while I get that done. I can only do a little at a time in the mornings.
Meanwhile I'll also breadbord and test the siren setup in the cool of the house.
My favorite lakes are down so much that the ramps are closed anyway. This Extreme drought is getting old. UGH. :cautious:
BWR1953
And I'm back to work on the boat again. :sneaky:
Health issues knocked me on my butt (literally) again earlier this month. 🤕
We lost a vacation as a result. But, I'm doing better now. 🤪
I started cleaning the boat this morning, then found that the glovebox appeared to be broken. But when I took a closer look, it was simply not reassembled after being painted. I'd saved the parts in a used aspirin bottle and marked it as such. Cleaned it up, got the parts and tools, put it back together and it's now remounted.
That's one more step to hit the water. My wife is burning her vacation time now, so I'd like to get the boat back on the water so we can at least have fun with that even though we had to cancel our trip.
Anyway, here's my first step.
Wider view showing the trolling motor batteries under the console.
redneck joe
Side note, i tripped over myself a couple three nights ago in the garage and am no nursing what appears to be a cracked (back) rib so i'm not doing much of anything for a few weeks...
BWR1953
I did some more cleaning/clearing and bundled the wire harness as best I can. That bending over upside down stuff ain't for me nowadays. 😵‍💫
The "correct" way to fix that drooping wire bundle is to open it up, cut into each wire separately, insert a long extension, then solder everything back together using marine heat shrink and so on. I won't be doing it this summer. Maybe in the winter with the boy's help. Or who knows, just use it as is and let my neighbor buddy worry about it when he inherits the boat from me. :LOL:
The problem is that the controller came from a bass boat and the length is shorter than that of the MC. Further, the MC gunnel isn't available to reach from underneath. There's a panel coming down at an angle from the side of the gunnel to the side of the boat. Makes it super tough/impossible to stuff the wires up under there. I don't know if this is an "as designed" feature or if some PO put it on there.
5.jpgThis is another issue I'm going to let slide awhile. That red lockout needs to be repaired/replaced. It ain't gonna be me doing that! I'll get my buddy to do it sometime in the fall or winter.
BWR1953
are those seats really that short??
Oh! Yes, they are. They're from the donor bass boat. I intend to add some posts to raise them up. "It's on the list." 🤪
For temporary use, I have a seat cushion from my truck to use in the boat. The passenger seat in my truck is very low and not adjustable for height, so I bought a 3.5" cushion so that my wife sits higher. The driver's seat is fully adjustable.
I sometimes use the cushion on my JD 150 riding mower to give me more comfort than the stock seat.
And my passenger in the boat can sit on the throwable life preserver. 😁
