jimmbo
- May 24, 2004
- 14,293
Thanks for this pictures this clears my mind a little bit I guess it seems everything is casted together in iron or some material as that, this means this can withstand better over heating? The jacket cover still aluminum I guess.For decades, Mercury, on its Inline Engines, had no removable Cylinder Head. Removal of the Water Jacket Cover on one of the older inlines, and you would see this. That changed on the V6s. Your Engine is like the 1st Gen, no Head, but might look a little different with the Jacket Cover off
Since the water jacket cover plate is a non-functioning element of the engine block, and you are sure its what's leaking...usually around the spark plug openings, if you lay the cover on a flat surface and it appears to be warped, just add more gaskets and glue between them......is what I'd do.Replacing the Gasket, may or may not result in fixing it. The Water Jacket Cover may have warped, if it ever had gotten too Hot. I replaced the Gasket twice on one of my motors, lasted longer when installed without Sealer. Replacing the Water Jacket Cover solved the problem.
