Scott06
- Apr 20, 2014
- 7,503
I need bowl and metering block gaskets for my friends holley 2 bbl on his 4.3 VP.
is this the correct gasket set https://www.holley.com/products/fue...r_components/carburetor_gaskets/parts/108-200
It says 4150 gaskets doesntmetion 2300, but if you buy the gaskets individually holley states 2330 and 4150 - so I assume they fit...
when I last rebuilt this carb in the past I bought a OEM VP kit because I couldn't find the OEM carb number in holleys literature. It is a stock VP 2 bbl carb, 2300 style, but suspect they obfuscate the normal way of getting Holley parts off the airhorn #.
@Scott Danforth - I figured you would know...
he is selling the boat for parts as after fighting fuel contamination, he found the transom rotten in addition to needing bellows.. I know if the carb is cleaned again we can run it off an OB tank... its a shame as interior etc is in good shape. 2002 glastron GX185 4.3/SX drive. PM me if anyone needs parts as engine is fresh water and in great shape.
