Chaparral19h20
Thread starter- Joined
- Aug 10, 2024
- 5
2012 Chaparral 19 H2O 4.3L MPI SN: 2A040699
So I did a dumb thing. Had the OBD service light come on, (no apparent performance issues) and I read that by jumping the OBDM terminals I could pull codes with a multimeter. As soon as I turned the key, the normal startup alarm stopped abruptly and the key went dead. All other circuits function fine (except the trim tabs) and I suspect a fuse blew when I shorted a circuit. I’ve spent 5-6 hrs. all over the boat going through everything I can find but cant find any blown fuses. I’ve tested the three main relays and replaced the 90 amp fuse at the starter for good measure. There are 4 O2 sensor fuses and 4 main engine fuses under black oval caps that all test good. Found a 2 amp fuse under the ECM in a single fuse holder that was also good. I’ve read online that there is a 15amp ignition fuse on the back of the merc 4.3 mpi down by the distributor but can’t locate one.
Appreciate anyone with suggestions for where I should look next. Thanks!
