Aluminum transom has had heat distortion
Seasons Recreational
I’m hoping to circumventdiscussion about whether pontoons or float pods are effective, and I have a problem.
I bought float pods from Beaver tails and had a local welder weld them onto the transom. The process of doing so completely distorted the transom. He’s willing to bang it back in the shape, but it’ll never be straight as it was. Are there any suggestions as to what is the best course at this point? Should I have him try to bang it back in the place? Should I replace the top section of the transom above the float pods? There’s some distortion below the float pods, but it’s minimal and I think it would be OK to leave. But I really need the upper section to be straight so that once the Coosa board transom is in, I can apply the cap over the top.
Any suggestions from the pros would be greatly appreciated! Thank you so much.
Adrian
MikeSchinlaub
Wow, I hope you didn't pay for that. The welds are good, but he should have known not to just do it in one long weld.
I don't know, that's a lot of warp to try to hammer out.
I will not disclose whether I paid for it or not, but I guess that answers the question for you!
I'm not a welder, but I think they do look good. He did say that he was going only about 4" at at time, but you're right, as soon as he got some deformation he should have stopped.
The good thing is that he is on-board to try to fix it, but I am just not sure what the best fix is. Aluminum does get work-hardening, so I am worried that it might be brittle. The transom has a flange all around that rivets to the gunnel. I was thinking if he cut the material out about an inch or 1 1/2" from the edge of the transom, and if he provides me a new sheet, I can maybe run a ton of rivets from the new transom to the flange, using 5200 to seal the two.
Last think I want is the transom to break loose in the middle of the lake!
Should have had a backer in the boat, like a sacrificial chunk of wood to help control warping also, in addition to a heat putty, should have stitched it 1/2" at a time, jumped 12" rinse and repeat. 4" is too long on thin sheet metal. also, the fillets are for 1/4" plate, so there is way too much heat.
MikeSchinlaub
Ok, I'm not much of a metal guy, I mostly do fiberglass, but I'll give my opinion on fixing that.
I think it's stretched too much to just bang it back into shape. The only chance, and this is with no experience, would be a lot of work with a shrinking hammer (picture attached below). It looks like a meat tenderiser, and works by making loads of little dents to shrink the metal. I don't know if it can take that much out, or if the texture would be too deep for the thin aluminum, but I think it's the only chance of saving that sheet metal. Then it would have to be filled and resprayed, and sanded before hammering if you're going to try it.
The other option would be as you said, to replace the whole panel, which means drilling out all those rivets, shaping new metal, putting in probably about 200 new rivets with an air hammer and dolley, and repainting the rear and sides. Oh, and redoing the work for those pods, which is a real kick in the nuts.
If you go with a new panel, maybe next time have some brackets made and weld those on so the pods can be removed if that would work.
Sounds like you are versed in welding! Any suggestion for best course to fix?
Thanks for your suggestion Mike.
To fix it, can't you bolt or weld a 3/8" thick aluminum panel to the transom, gunwale to gunwale? Maybe remove the knees, and put the panel on the inside of the transom, and then replace the knees?
Texasmark
Am I correct in assuming that there is an aluminum cap that goes over the parts shown in your last picture? If it were mine I'd force the cap in place and bolt everything together as tight as it would let you.
First I'm not a metallurgist! So in thinking I would consult one (of sorts) I did a Google AI search and came up with this: if sheet aluminum is over heated, does it have a memory......plug this statement into your search engine and check out the results.
The worst part of the answer is that the aluminum that has been overheated looses its hardness due to destruction of the additives that make it hard....answer contained in the statement. With that said, and being a farmer that sometimes having to (field) modify things to get a job completed, X-lifelong boater, I would try to fix it.
First thing I would do would be to bolt the transom to the piece of wood shown in your last photos. If the aluminum accepts the tension and moves, or attempts to move back to the wood where its bowed out, I'd look around for a 1/4" thickness of 5052-T6 Alum sheet and scab it to the outside of the transom with bolts and sealer, covering as much of the transom that's allowable.
Then, assuming that the aluminum cap won't cover the increased width, either "joiner" down the thickness of the wood 1/4" (best idea) to fit, or cut the rear vertical part of the cap off.
Since this is a small boat and probably won't see more than 10 HP, I think the gamble is worth a try.
On the extensions on the transom, it really helps keep the stern up and on the Texas coast, when I was growing up. these extensions were common on popular, upper class, wooden boats at the time, and they were dual usage.....helped to keep the stern up at slow speeds, and were ported, allowing ambient water to come and go making a convenient place to put live shrimp when bay fishing for Speckled Trout (Spotted Weakfish) schools.
First, smack the "welder" in the head.
The metal is already half its strength from welding. Best you can do now is back-cut the inside along the weld and weld over the seam. It will take someone who knows fabrication of aluminum. You ain't going to beat that out. You need to thermally relieve it by back welding.
You need someone that understands ship hull welding
Texasmark
The idea of the 1/4" sheet scab is to eliminate further heat entirely and to replace the original transom strength aluminum with the scab (bolted) on replacement. With the original aluminum loosing its strength, bolting the scab on ought to be a no brainer as the variations in the original transom will yield to the attachment of the scab plate, smoothing out adequately, and you are good to go......but we all have different ideas, backgrounds, likes and dislikes and so on. It's YOUR boat and your decision.
Mc Tool
I guess it sorta depends on the circumstances......you say "a local welder" , was this job done as a "not really our thing but we will have a go" at a cheap price or did they charge you full whack ?
If it was the former then Id be prepared to let them patch it up as best as practical, but if it was the latter Id be taking it to another (experienced in ally boat building ) sheet metal workshop and getting a quote to repair and a suggested method of repair.
It not like it was a newish boat in excellent condition so there is some risk that any proper repairs would exceed the value and you might be faced with a cash payout and no boat . You might be better off accepting a half arsed repair that makes the boat safe but not pretty and putting it behind you .
Frustrating when you pay a professional to do a job that turns out to be of poor quality and when the dust settles your still left less than whole ....and they move on ....to do it to the next guy .
peter22
If there’s any flex or signs of rotten core material, a proper rebuild is probably safer than trying to patch it again. Aluminum can lose strength in the heat-affected zone, so it’s worth having an experienced aluminum boat welder inspect it before running the boat hard.
It sure, but thanks for the input Chris.
Ok, I have a cousin who is specializes in airframe construction. He was in the national guard and repaired planes with rivets, etc. and has the tools (rivet gun and bucking bars). I want to present this to the group to see what you all think:
The deformation is almost all above the pods. What if I cut the transom out, but leave a flange of about 1 1/2” as shown in orange (radiused corners). My cousin can rivet it together and we can sandwich it in 5200. This would avoid heating and additional weakening? This would also allow me to use a bit of a thicker panel (maybe 1/8”) for the new ‘upper transom’ and I could overlap it a bit more at the bottom seam, maybe 2”.
The riveted seam should be above the water line and above the knees.
The way I so happened to shape the Coosa board transom, the center section is extended lower and I suppose I can add another couple of sealed thru bolt hardware attachments to either side of the center knee (coosa board to existing lower transom section). From the inside, the riveted seam would be behind the coosa board and should not be visible.
I do have some deformation of the knees, as you can see, but minor enough I think.
Thoughts?!
If you're going to do that, why not just do the whole piece?
Thank you all for your input. To tell you the truth, my dad is in hospice and this boat project sort of serves as moments of relief as I am able to work on her.
Welding on the float pods was to be the last major item before I paint the back stern and do final assembly of benches, motor, controls wiring, etc. I was so excited.
Having the transom butchered sort of took the wind out of my sails (forgive the marine reference). I'm fighting through the disappointment of what has happened, but I think it's salvageable. Given my position, I just can't go down the rabbit hole of popping 200 rivets to remove the full transom, to only have to remove the pods from that old transom, learn how to form a flange on a new piece of aluminum to then place 200 rivets in hopes that it is watertight. After which starting from zero again with the float pods. Even if it is the most proper fix.
I am hoping, rather, that I might be able to just remove the portion above the waterline, still apply a second tier proper fix and get back to the exciting season of reassembly!
The question, I suppose, is that on the boat there are two staggered rows of rivets, about 1" apart, so basically a rivet every 1/2". Do I assume I should keep the same spacing?
Hoping everyone is ok with a little personal data. There are events surrounding our pursuits that effect them, but I'm so glad to have the forum and this purpose of completing this tinny!
Thanks guys.
What do you mean "the whole piece"? Looks to me like he has outlined as much of the transom covering as he can. If the knees are questionable, and for 10 HP I'd really doubt that, then just add additional knees.
Thanks Mark, right now I am planning a 15hp 2-stroke Johnson.
