removing a pontoon off the trailer on land
warddog
Been away from this for a while but did do some work on the pit since my last post. I had numerous BIG boulders from when we built our house stacked up so I did some dirt work and then put some boulders into the pit as far out as I could reach and maneuver. I also put in the dock and had to wade out in it to set the poles and that is how I know the muck is at least shin deep. At the end of the dock, I was crotch deep including the muck and water. The dock itself is 10' long as is the piece on the shore so that gives an idea of how far out the dept is. I'm going to attach some pics as to exactly what I have now. My concern is getting this thing out, sinking in the muck and not being able to go either way should the pontoon not be able to float off the trailer. My mind says JUST DO IT but my dreams keep saying you'll get stuck. LOL My truck is a Chevy Silverado 4x4 with the big 5.3L V-8, so I have the HP to pull and hopefully can get the traction if DRY. I have NEVER done this on a good lake with boat ramp much less in a mucky bottom pit.
warddog
This is the ramp down to the edge of the pit where I placed the BIG rocks. I hope I can get the trailer in and out of this so as to load the pontoon back on. NOT doing so before has me wondering if the trailer wheels will go off the rocks and then sink into the muck making it hard to pull back out.
redneck joe
put fence posts about a foot before the end of the rocks and mark the wheels somehow when they line up you stop.
Jeff J
It’s bad to drop the wheels off anything hard. I ruined a wheel, tire and fender at a washed out boat ramp one year loading a pontoon boat.
warddog
I doubt that if I do not get out past the end of the rocks it will not be deep enough to float the pontoon. If I do go past the rocks the wheels will drop into muck. I have not waded out there since I dropped the BIG rocks into the pit mucky bottom but do know it was shin deep when I waded out into it to put the dock pipes in. STINKS bad too! LOL It appears that the previous owner did something similar as the trailer fender on one side is bent up like something hit it from under it. It now has rained over three inches so my launching will be postponed until it dries up again which gives me more time to worry about it all. My biggest worry is getting it off and out of the pit. I've already got repairs to make on the trailer.
Grub54891
Looks a lot to me that you should dig out the launch area and put in a good base. Gravel and such. That alone will help with launching and retrieving. A good contractor would probably fix the underwater part good enough for a nicer surface.
FLATHEAD
Can you get the trailer out to the edge of the rocks. Back it as far as the rocks allow. Here is a wild idea. It’ll take a roller and winch. You could bolt a roller on the back of the trailer. Anchor your winch to your truck/ tractor or whatever will hold. Run the winch cable under the trailer around the roller then run it under the toon all the way to the front. Hook it to the toon down low. Then winch away. In theory it should pull the toon off the back of the trailer enough to get it to at least start to float.
Just a thought.
Jeff J
Just a thought.
What would you hook to on the boat? There isn’t much on a pontoon boat design to handle that kind of stress. I saw a video on reels the other day. The rear cap was ripped off one tube. The only thing I could think of for a cause is they hooked a tube to it.
FLATHEAD
Hard to say without looking at it. I know it’s stripped down so the weight is less..
redneck joe
Just hit me. What if you pulled the boat about a third to a half off the trailer while on land. That puts the float point farther back. Prob could do more if you strapped the bow tight to the trailer but that might be too much stress on the tools.
flashback
Maybe you could corduroy the ramp area if you have access to some loblolly pines
warddog
Forgot to update all you good folks that have offered ideas. I backed the trailer right down into the pit on the rocks and unloaded the pontoon. It worked well other than the driver's side had a rock slip and shifted the trailer to that side so it wasn't straight back. We merely had to get in the back of the pontoon and rock it back and forth for it to float off. I'm thinking that I can put it right back on to remove for the winter as well as I had NO, ZERO problem pulling the trailer back out. I will try to get in there to see if I can fix the rock that slipped` and or put more in. Thank you to all that offered up ideas.
