What is the correct name for this breaker?
crazy charlie
I may have to replace this...whats it called? Everything fine when winterized.Now my Yamaha OX66 on my Grady starts and tilts fine but nothing else is working.Is this a main breaker?? Resettable or replace?? Puzzled . Charlie
dingbat
That is the circuit breaker for the main power of the boat. Trim power comes off the motor side.
Pretty robust. Have not had an issue with mine. Pull the two screws on the transom and put a meter across the terminals on the back.
Texasmark
Thanks guys ,will do.Pressing the red button is basically a reset??
It's on there for an unexpected current surge. If that happens the internal circuit breaker opens. As alldodge said, the button is to reset it. Before you go to a lot of trouble push it and see if it resets. If so, fine. If not one of 2 reasons: Broken internal switch, or continuous current overload.
crazy charlie
Thanks, kinda weird that all was fine when winterized and it's just been sitting. Puzzling but will check .Thanks Charlie
crazy charlie
Not much room without removing a battery but the connections inside the breaker that I can see are pretty crusty looking. What setting does multimeter go.on for a test? I have a Greenlee DM55 ,I'm thinking V--20? Never used a meter before. Lol. Will try to post a pic of crusty breaker
alldodge
yes, 0-20 you should see full Bat voltage 12.6 to 12.7
Black probe on Bat ground
alldodge
no, red probe on one of the terminals and black probe on ground of Bat of the block
Put red probe one at a time on each terminal of the breaker, they should both read the same
crazy charlie
Ok ,it's seems like the connections are the issue. Too crusty. Neg on battery and probe on 1 connection reading was less than 1,when I moved probe half inch from the connection 12 came up
alldodge
Remove the breaker from wires and clean everything up and reinstall
When you have breaker off and clean, put meter on ohms scale and touch one probe on each terminal. You should read 0,0 ohms
Note, don't do this test with any wires connected to it
crazy charlie
Ok got it. Just testing the breaker alone at that point. Thanks. I just sprayed it down with deep creep Seafoam and will tackle removal tomorrow. I don't think connections are coming off easily. Thanks again
crazy charlie
Would jumping the breaker confirm this is the issue as well or is that a bad idea?
alldodge
Yes, but keep in mind jumping it with bad connections may not change anything if jumper does not make a good connection
Just clean the battery cable connections
crazy charlie
Hoping I don't sound like a complete tool here but should I be able to temporarily connect the 2 leads together after I remove the breaker and until I get a new breaker if needed?? Just to keep my bilge pump connected for a day or 2 ??
