Mercruiser 5 L mpi cooling system
affa
Hi,
I started the engine without the drive installed to heat up the oil before changing it, it come some water out in the exhaust and it was much white smoke, I thought the water would circulate inside engine when thermostat was closed? It has been winterised with antifreeze, my concern is if something’s gone wrong in the cold? It’s not closed cooling, and it’s the type where you can remove a blue plug in the bottom to drain the water from the engine
Regards
Affa
Since you did not have cooling water flowing to the motor when you ran it, you burned all the rubber bits in your exhaust
the white smoke is most likely steam and burning rubber
If you drained the block, heads, and exhaust manifolds prior to adding antifreeze, you should have been protected
affa
Ok thanks, the rubber in the exhaust, is that the flappers?
flappers and the rubber exhaust couplings. both rated to 250F max. however without water running, your exhaust goes from 200F to 950F
Jmunk
How long did you run it without a hose feeding in water?
affa
Not long, the riser’s wasn’t hot, maybe for 5-10 minutes, and it came some water out,
(that’s why I wondered, didn’t think it would come water out when I had no water feeding),
It was winterized to the top with antifreeze
5-10 seconds is max to run without water. at 5-10 minutes, you definitely burned up the flappers and most likely the rubber connectors.
Jmunk
No water came out due to the fact there wasn’t any water pressure to push it out. Best case it’s just the flappers and rubber couplers that need changed. Worst case the engine overheated.
alldodge
If motor uses a Bravo drive than also the impeller is burned
affa
It’s an alpha drive,I’ll check the rubber parts
affa
Are there any problem using the boat with worn out flappers?
Lou C
Well, it's hard to say, but if the static water line is just high enough with no safety margin it is possible to get water up the exhaust if you slow down quickly. They are there for a reason....
The pix I posted above are to show what happens during an overheat, vs a good flapper.
usually the burned flappers drop down the Y-pipe, plug exhaust causing the motor to run like crap, then the flapper pin wears a hole in the y-pipe and you develop a leak in the boat.
Lou C
I had to pull the outdrive to get the rest of the burned up flappers out they were in the exhaust passage, lucky the pins stayed where they are supposed to be.
Not sure if this applies to the Alpha or Bravo drives but on OMC Cobras and Volvo SXs there are water tube grommets that will also get overheated and softened/melted, due to a lack of cooling water. So splitting the drive the check all that, is wise after an overheat, or else you can have an overheat that you can't figure out!
Scott06
its not ideal as they put them there for a reason, but have had no issues with a boat where when I changed them it was obvious they had been not working for years.
Lou C
It's impossible to generalize because every boat is different, some have more than enough static water line height, some are marginal, if the driver is prone to rapid slowdowns, if a heavy swim platform is added, etc. all those are factors. If you REALLY want to know, learn how to measure the static water line of your boat!
