Question About Speedi-Sleeve Installation
Mark R.
I am currently resealing our Alpha One Gen 2 outdrive.
And I have ordered a Speedi-Sleeve for the yoke shaft surface.
Looking ahead, I am wondering how this sleeve gets installed.
It comes with an installation tool for driving the sleeve on.
But the protruding shaft spline will be in the way of that tool.
So will I need to drill a hole in the center of the installation tool.?
Or do you guys use some other pipe or tube to drive the sleeve on.?
I freeze the shaft and put the sleeve in the oven and heat to 350. Then drop on
Mark R.
So with this method, you don't need to drive it on at all.?
The video I saw from SKF said not to heat the sleeve.
They were concerned about it warping since it's so thin.
I do really like the idea of freezing the yoke hub though.
In my case, I'll need to freeze the entire universal joint.
Wife should love that. I'll seal it all up in a plastic bag first.
Ayuh,...... by using an oven, rather than a torch, it won't warp or deform,....
jimmbo
Wait till she finds out you used the Dishwasher to wash the Parts
Mark R.
That does make sense...
So with this method, you don't need anything to drive it on.?
It seems like I will still need some way to carefully tap it on...
Ayuh,..... With the yoke frozen, 'n the sleeve at 350*, it should pretty much fall into place,....
If yer that worried 'bout it, prep the "Tool" before hand,....
Mark R.
I have a buddy who replaced his kitchen dishwasher.
The old one still worked fine, so he installed it in his shop.
It works great for cleaning all kinds of stuff.
Mark R.
OK. Sounds good. I will use that method.
What do you mean by "prep the tool"...?
I use the dishwasher on Fridays when I get home early to wash parts
I also use the oven to heat ring gears for flywheels and to heat carb parts for painting
Mc Tool
Yep ,even heating and cooling the bits .......still pays to be ready to drive it on if you have to . Getting one stuck halfway on is pretty much a "cut it off and start again with a new sleeve "
There is a knack to doing these so dont be bummed out if you need 2 goes 🙂
Mark R.
^^^ This what I plan to do.
I will drill a center hole in the tool and have it ready.
Thanks guys.!
Mc Tool
FYI
Anyone finding the dishwasher parts washer idea should keep an eye out for an older commercial dish or glass washer.....or at a pinch and older dishwasher with the old clockwork timer, and if you can get one with a stainless sump ....as opposed to plastic ...bonus
Mark R.
Update:
I found that a 2" PVC Coupler has an inside diameter of 2-3/8".
That worked perfectly as an install tool for tapping the Speedi Sleeve on.
And it only cost $1.56 at Home Depot... :)
A new question regarding this same topic:
Do you guys normally try to remove the tearaway installation flange?
Or is it customary to just leave that piece in place.?
It doesn't appear it will interfere with anything or cause any problem...
