DeWalt corded drill DW106 Type-2 keyless chuck, bits slipping out?
ezbtr
DeWalt DW106 Type-2​
The DeWalt DW106 is a 3/8" variable speed reversing (VSR) drill with a keyless chuck.
Some bits slipping out, what's the fix? Thx guys
MikeSchinlaub
Crank it reeeeaaallll tight? Usually that only happens once, then when I rechuck the bit it stays. I think sometimes the hex bits don't tighten down on the flats, so they slip and come loose. I can't explain why the smooth shank bits do it too.
dingbat
Have two…absolute junk chucks
Looked into a decent Jacobs chuck but never followed up.
Much easier to just grab the Milwaukee hole shooter out of the drawer if I need something capable.
Jeff J
I had to change out a keyless chuck on a brand new Dewalt for that reason several years ago. It simply would not hold a bit. Tightened it as tight as I could. Bit would feel tight but come loose almost instantly when in use. Dewalt sent me a replacement chuck for free. I opted for a keyed chuck. It is the only keyless I ever owned that did that.
I don’t know the model but it is a Dewalt 3/8” corded drill. I bought it in 2014 or 2015.
Mc Tool
You could try blasting it out with aerosol degreaser and compressed air . I used a ¼" round saw file in the chuck to make sure there were no hight spots in a Bosch drill chuck .
Annoying as it usually results in gouges in the drill shank ....and then they dont fit back in the box .......and look bad
ezbtr
works fine w/ Bosch 6 sided chuck for driver bits - grrrrrrrr :(
ezbtr
just ordered keyed chuck for $20 from Ebay , I really like my old Dewalt ;)
Jeff J
I know what you mean. I grab mine anytime I have serious drilling to do and I have a place to plug it in.
Mc Tool
You can get a good, medium duty Jacob’s for $50.
Yeah maybe in the states but by the time I convert to NZ$ that is $95 , plus ,$50 to $75 for freight ( freight x US is probly the most expensive there is ....Italy is hight too )and Im over $150, and bought locally ......there is precious little if any to be saved .
The keyless chuck on my 18v Makita is still good after 20 odd years , press chuck needs all three holes tightened and I dont use the ( 240vac) Bosch any more coz I sick of wreaking good drill bits in it .🙂🙂
Mc Tool
What are you drilling into ? Makes all the difference.......
Steel , but I think that particular keyless chuck is needing a hoozle up, it should be ok as its all steel but I think its time to take it apart for a clean and debur, shame coz otherwise its a good drill .🙂
flashback
I wonder if you could dip the shank in lapping compound and polish the jaws?
FLATHEAD
When I retired we had a ton of broken dewalt tools. A shelf about 30 feet long 24 inches deep full. Everything from drills, sawzalls, grinders, various sanders, impacts etc. all cordless stuff. Crew of 15 tradesman, switched via attrition to Makita and Dewalt. If I was still there I could have sent you a chuck. We kept them to show they were broke in case the business manager showed up with invoices asking questions. Never got around to tossing them.
dingbat
Yeah ,thats where I was going with the round file 🙂
If that works you found the problem… a good quality chuck is harder than a file.
Since you’re down under, look into Accuratecut chucks. Good quality, made in Tiawan
I have tossed out two drills with lousy chucks, in the last year or so. I live on the water, and if you are working on the dock and you drop something like the drill bit you need, it is gone. Life is too short for that.
The hex shaft drill bits help keep the chuck tight a bit better.
airshot
Drilling into steel needs a good bite on the drill bit. Many over tighten the chuck and over time the chuck gets ruined. As a retired toolmaker, I often ground three small flats on my drill shank to give the jaws a place to bite into without overtightening. Using the hex thanks drill bites also work for the same reason. I have saw folks using pipe wrenches and channel lock pliers trying to get the "hand tighten" chucks tight enough to hold, but once they start slipping, the jaws end up ruined.
