Shifts into reverse but won't shift into forward
peters715
69 Starcraft w/2.5.
Out of the water the prop locks into gear in both forward and reverse.
In the water it shifts into reverse perfectly.
Shifting into forward nothing happens other than the engine reving. With it in the water, motor running shift cable disconnected, I pushed the lever until I felt the gears just starting to touch.
From this I see that the cable does not have anywhere near enough extension travel to push the lever into forward gear.
The barrel is adjusted as far out as it can go and is still way short of how far it needs to go to engage.
If I had to guess, it seems like to the forward gear has slipped backwards on the prop shaft (if this is even possible) as the dog travel is further for forward than reverse.
Anyway, I am open to suggestions, ideas or theories.
Remove gearcase.----put gearcase in neutral.----put control in neutral.---adjust the barrel.-----install gearcase.
Ayuh,..... How long has it been since the lower shift cable has been replaced,..??
peters715
Lower shift was installed recently, never been in the water.
peters715
Just checked and the shift rod is engaged with the lever. And with the shift in full forward when I spin the prop by hand it barely ticks.
I did change out the old MercControl for a Commander unit. I adjusted the shifting with the Commander and it was fine in the driveway. But now there isn't anywhere near enough throw on the cable to get it into forward gear.
alldodge
Need to start from scratch with the cables, there not adjusted correctly
kenny nunez
2 Xs with AD. There must be 3“ of shift cable travel from the control box from full forward to full reverse.
Another place to check is the pocket in the upper housing where the shift slider travels for forward. Quite often there is a build up of old grease and marine corrosion which restricts the slider from going far enough for forward gear.
peters715
Alright, figured it out, for the most part.
It does shift into forward. The issue was I had purchased a used Commander shifter and the internal configuration was actuating the throttle as soon as I pushed the lever forward.
Opened the shifter and changed the linkage and throttle does not actuate now until the forward detente has been passed.
I am able to shift into forward and reverse but as the lever nears the dent the gears grind a bit. If I push the lever to the dent faster, not quickly or like it's a quick draw contest, it goes into gear with a clunk.
I am able to disengage from forward and reverse with out issue.
My question now is if these behaviors are normal and there is a technique to shifting, or I need to refine the adjustment?
Ayuh,...... Normal,.... shift an Alpha, briskly,....
