1990 120ho force king pin question
gica
Cut yourself a slice of soda can the length of the outside circumference and the hight of the bush and and pack it in behind the bush .....if that dont work put 2 i
I already installed the motor but not the drive.
Is there any issue if I leave it like this?
Again the plastic bushing sleeves when in pretty tight to the wall of the swivel bracket. The king pin itself has a little play in those 2 bushing bearing sleeves. So how can I fit anything on the back of those when the play is b3tween the king pin and the plastic bearing sleeve?
I didn't know you have to Jerry rig it.
I really don't want to remove it again if it's not
mandatory. Why the heck is there the play. The king pin is authentic and m e assures exactly like the original.
The sleeves are new so I don't know if the ID is larger 5han the older ones. I measured and maybe 0.05 maybe.
I inserted the older king pin and it also has play.
I have not packed the swivel bracket with grease yet. That might tighten it up maybe.
Again is there a problem to leave it is?
gica
So I measured the ID for the new bearings is around 28.80..
The old bearing is 28. 28mm.
So 0.6mm bigger on the new ones. The old and new king pins are the same diameter and outside diameter of the old and new bearings also measures the same.
gica
Not an easy job.
To make it easier, the head and lower unit needs to come off.
If it's ever been in salt water?? 10X harder.
Need a factory manual too.
An acetylene torch helps.
Take pics and post the procedures when done.
Hey Jerry any thoughts on the new king pin and new bearing sleeve bushings having some play after install? Have not packed them with grease yet.
The new king pin is the exact same measurement as the old one. The plastic bushings seem a bit larger in the id by 0.5 or so. Is this normal? Will it be batter when packed. The sleeve bearings were bought new from Marine Engine.
Let me k n ow please I am sure you've changed some. Thanks in advance.
Mc Tool
Having that clearance isnt ideal but its probly no worse than any motor with a bit of wear.......but it would bug me 🙂. My bushes have a cut down the side of them so packing them did work for me . Greasing them wont take up clearance but it will make them feel better for a while .
Probly your best bet is to get the correct bushes if it bugs you to much 🙂
gica
I bought another one from Ebay it's a Quicksilver
I will see if it's any different.
Like I sa8d the ones I installed are from Marine Engine. I didn't see a brand but was hoping they sell the right ones
I did install the engine but it would be easy to remove at this point it's only the sealant part.
The old ones have been heated so they don't even go on the pin anymore.
Any idea where I can find original ones?
I see some used on Ebay. They might be ok
gica
I just looked on Marine engine website and it 8s a E2 Mercury Quicksilver 23-819493 Bushing OEM New Factory Boat Parts. So it's factory.
Wtf.
Mc Tool
Yeah , ebay. I bought new bushes for mine ,did all the part number checks but when they arrived they were about 5mm dia to small......so they are still in the bag they came in .
gica
5mm
5mm?! That's a lot. Mine are 0.5mm larger. But since I heated up the bracket to get the old pin out I am thinking that caused some shrinkage.
gica
OK I measure it with a wire gap tool and as I expected there is a 0.5mm or below space there, the 0.025 wire tool was not easy to insert so it's smaller than that.
gica
Since I did not get any relevant advice on my particular model I went on ChatGPT and apparently the 0.5mm between the king pin and the plastic bushings is excessive it is supposed to be 0.1 so lubricant gets through. 0.5mm will cause clunking and unstable steering. So I guess I have to find two freshwater swivel brackets with the bearing bushings pressed in.
It seems the swivel bracket walls get out of round and that's why they don't squeeze the new bushings to get tight on the king pin. I guess that's why there is play.
So, MC Tool your idea with the aluminum can skin around the outside of the bushings will do that to a certain extent. But if it's out of round it still won't help.
Mc Tool
5mm
That bush is twice the length of mine so more supporting area ,if there is less than half a mill Id pack it with grease and grease it up regularly ,you wont know its there 🙂
gica
A guy from South Africa replied on a different forum this is what he said:
"The pre '95 Force engines used Chrysler design technology from the seventies with the commensurate problems. The swivel housing is one of them: if wear of the king pin bushings is not caught on time, the king pin will hammer the bores into an oval shape. This will go on to break the bottom cowling, wherein the king pin has a press fit. This will lead to the motor breaking off and in the worst case, you biting into the steering wheel!
Solutions: Try to find GOOD condition replacement swivel housings on ebay or in breakers yards. Your NEW bushings must be shrunk in, to sit tightly in the swivel housings. Use red LOCTITE or epoxy! Grease is not a glue! You can (at great expense - and only if you have a friend who is handy with a lathe and a boring mill) replace the damaged king pin areas with a newly manufactured Aluminium spool, after cutting out the worn out area on a boring mill. Now you need another friend who is handy with a TIG welder, to weld in the fresh spool. After welding, finish machine the bore to accept the top and bottom bushings, after heating swivel housing to some 60 to 70 degrees Celsius for a nice shrink fit. This is the racers (expensive) solution to your problem. Please note that post '95 Force parts will not fit, as they are Mercury based. That includes top and bottom cowlings, adapter plate, tower housing, transom bracket, lower unit and power trim. NOTHING fits between the 2 models.
Rgds, Wolfgang (South Africa)"
How the heck do you shrink in the new bushings? He mentions Loctite also probably on the outside to lock them in. That way the grease goes only on the inside of the bushing. Still trying to get the clarity on it.
Mc Tool
Yeah , do that .
jerryjerry05
Is Jerry still around?
Yes still her, been under the weather and my knowledge on this area(kingpin) isn't the best. In all my years, I've never taken one apart. I've just been lucky enough to be able to free them up and get them to work.
75 and slowing down and it's friggin FREEEEEZIN out there. My hands stop working when I get cold, good luck.
gica
Sorry my man hope you feel better and stay warm.
