1995 Crownline 202BR Restore
beta
Productive day today. Got templates for all my stingers and bulkheads cutout and test fitted. I decided it was going to be near impossible to get the height just right right so I'm making them all a little tall and will cut them to height once they are installed. I'll use the existing stringers to set the deck height.
Need to cut a template for the ski locker floor. I decided to put a bulkhead at the bow end of the ski locker so it's totally enclosed. The previous ski locker was open all the way to the bow. This will allow me to foam the areas in front of the ski locker and everything outside of the gas tank area. Also I will not have a drain hole in the forward bulkhead around the gas tank. It's clear that water was flowing up and down the keel and under the ski locker previously.
beta
Got the stringers and bulkheads cut out and fitted. Forgot to double check the length on the ski locker sides after the bulkhead was fitted. They ended up being about 1/2" short. I was able to salvage the longer one by using it in place of the shorter one so only wasted one of them.
beta
After dry fitting everything and cutting the tops to match the existing stringer height, I've wrapped all the new stringers in CSM and dry fitted them again. Had to do some sanding/trimming on the cut end of a few of the existing stringers to get a proper fit but everything is falling into place. I tried to leave a little extra room between the existing stringers and the new so I can CSM over the ends of the existing stringers where I cut them. I'll do the same on the tops of the existing stringers which I've already sanded down.
On the bulkhead, you can see where I made cutouts for the fuel lines.
The one new piece I have not wrapped in CSM yet is the strip that goes along the keel. Being 10ft long and curved is going to make that fun. That's on the schedule for tomorrow along with putting out Christmas lights.
beta
Been making some good progress but need to catch up on my postings.
All the stringers/bulkheads are installed with PL. I wrapped everything with CSM before installing. Everything from the gas tank bulkhead forward is glassed in place.
About half the back section is done and plan to finish that up next weekend. Once that's done, I'll put cleats in to secure the deck.
Tough on the back and knees but it's coming along. My technique with the bubble buster has improved a lot. Biggest challenge is the constant in/out of the boat to make PB, make resin, get supply x or y. Having a second person available would make a HUGE difference. Also, I'm getting the timing down on how much to glass at a time. Balancing the amount of PB and resin to make while assessing how fast I could apply it in a given situation took a few trials (and their associated errors) to get right.
I pored foam into the space below the ski locker floor. That went pretty well. I taped up the opening really well and glad I did. The foam is incredibly sticky and would be a nightmare to get off any surface.
After finishing the stringers, I plan to wrap the inside of the ski locker (wall to floor to wall) with CSM, followed by a gel coat to ensure a robust encapsulation.
Speaking of gel coating, are their any instructional resources recommended on how to do this properly? From what I've researched so far, I'm leaning towards applying 2 layers of unwaxed gelcoat, then a 3rd layer with wax. Does that sound reasonable? What I'm really unsure of is the technique to get the gelcoat down so it looks good and is functional. Also, what roller(s), etc are best to use for this? And lastly, some idea of how much gelcoat is needed for a given area (i.e. per sqft).
MikeSchinlaub
Ensign
How I would gel that ski locker.
1. Have 2 quarts of gel with wax ready, split roughly into pints. 4 cheap chip brushes.
2. Mix one at a time with 5cc of mekp.
3. Brush it on thick. Start with the high sides, then the bottom. Worry about coverage first, then making the brush strokes somewhat uniform. If you're quick, you can use one brush for 2 cups, but better to have extras ready. Also keep an eye out for pin holes, they're hard to fill. Brush over hard spots in all directions.
4. Clean up. Set the cups down on something not easily combustible. The cups will get really hot. Don't bother trying to save the brushes, they're toast. Clean off any spots on your skin with some acetone.
You won't get a factory smooth finish because that comes from the mold. The only way for you to get that kind of finish now would be to spray it and sand/buff it. I would also recommend some mat to help your gear drain and keep it out of the little bit of water that can't drain. Something like this.
Pmt133
I got an acetone sized jug, (gallon) did 2 coats unwaxed and 1 waxed on the bilge. I also did the anchor well up front, 1 waxed and 1 unwaxed and all the boxes under the birth, 1 coat waxed. I rolled mine out though. That left me either enought to roll 3 coats on the hull where it was either worn through or where I had done some touch up work.
beta
What kind of roller did you use (type and size)? Any technique suggestions?
What are the pros/cons of using a roller vs brush?
I'm definitely going to gelcoat the bilge but also thinking about doing the entire deck, then use seadek on top of that.
beta
I was planning to do 2 coats of unwaxed and a final coat waxed but maybe this is overkill. Are you saying to just go with 1 coat of waxed?
Approximately how thick should the coats be?
Agree on the mat and I have one from before the restore so good there. I do like the one you linked to better than the one I have.
redneck joe
Not sure on tech specs but gel and seadeck seems overkill. Prob wrong but I usually am
Pmt133
Just a cheap mini nap paint roller. (The ones that go on via the straight shaft)
No benefit. It was just easy and left a nice texture for the bildge and other areas.
MikeSchinlaub
Ensign
I've never used unwaxed gel, so I can't really comment on how it would work doing multiple coats and finishing with waxed. If you go with my suggestion, just get it as thick as you can without pooling. A big puddle will actually crack as it cures. It would only be an issue if you have a lot of excess, it's hard to get it that thick when you brush it. You have to be quick though, like finish the whole thing in about 5 minutes. It will set up super fast, which is why you split it into half quarts, any more will set up before you're half way through it.
I've also never tried a roller, but I would worry that it won't build thick enough because you have to press down to apply the material. At least with a brush, you can kind of skim the surface to move it around without dragging the thickness away.
beta
Finished glassing the rear stringers/bulkhead in place. With all the small compartments, it took a lot longer than I expected with the measuring and cutting the 1708 being the biggest pain. I used 2 overlapping layers including 2 layers in every corner.
The original layout had a channel between the motor mount and the inside stringer. There was a hole cut into the motor mount about 2" from the transom to let water pass through. I can't think of a worse idea than putting a hole in my CSM wrapped + 4 layers of 1708 motor mounts so water can pass through. I strongly suspect that's how the original transom was rotted.
Instead of a hole, I'm putting a slightly slanted piece of left over stringer wood over the channel. I put 2 spacers (same stringer wood) under the ends to give it the right height and angle. These were secured with PL this morning (they are under the wood so can't see them in the picture). I've wrapped the spacers and the bottom of the cover piece with CSM. Once the PL dries, I'm going to use PB to really lock the spacers in place and fill any voids around them. Once that is done, I'll PL the top piece to the spacers and fill most of the gaps around the edges with PB. I'll leave a few gaps so I can fill the cavity with foam. Once that's done, I'll glass over the top with multiple layers of CSM. This is probably overkill but I want to be sure any water that drips down in to this area quickly drains off into the bilge.
beta
Ordered and received another 10 gallons of resin this week. Hopefully my math is good and this will be enough for me to finish off the ski locker and the deck.
bakerjw
Great work so far.
When I did my rebuild, it was with epoxy. Took about a month before the budget overflowed into just throwing money at everything.
bakerjw
My Stratos rebuild was 94 straight days. Got a lot better after the demolition work.
beta
This cold spell has put a halt to my progress for the last 2 weeks. It's only ~52deg in my garage so no glassing.
bakerjw
My boat has 8" of snow on it ATM and it was -3F this morning.
tpenfield
My garage stays about 55-60˚F in the winter, so when doing fiberglass (which I am doing now) I usually run a space heater to supplement and 'tent' the work area with a small heater inside the tent, once I lay-up some glass. 2% on the MEKP.
Not sure if that will work for your situation, but worth a try if needed.
Scott06
Same here I run a 25k propane infrared space heater off a 20 lb gas bottle, works well except my wife thinking Im going to blow something up
