1990 Force outboard 230ho removed upper bearing by cutting and left a crease need advice
gica
So I removed the engine again because it had play up at the flywheel when pulling on it. After removing it I saw that the Loctite 518 near the bearing was brown in color and not red see Pic 3.
It also came off pretty easy so it did not stick. I was having issues with the engine stalling at idle. So I thought the bearing was loose. It doesn't seem loos to the hand. And from the look of the Loctite I don't know if the problem was the bearing or the two halves maybe not tight enough not straight enough or the crank not fully placed. I don't know
. But I tried to remove the bearing and it wouldn't budge so I cut it off diagonally.
I cut a small crease on the seat as you will see in the pics. 1 and 2
Wanna know:
if I can weld and fill it?
If I can leave it alone?
Or if I have to buy another used crankshaft. Found one from an 1988 125hp which has the same crank number as mine 817400T3
Let me know and thanks.
Mc Tool
Ensign
Loctite goes like that outside the joint when its old and dry .
Depends on how much /good the other crank is .
That gash is a stress riser ( like how you cut glass ) ........I wouldnt use it tho , if it lets go it will most likely take a good portion of the rest of the motor with it .
Next time get a puller of ali express .🙂
jimmbo
In my Opinion, that Crank is strictly a Paperweight now. Having it welded, machined, and treated, will cost more than a new replacement
jerryjerry05
The bearing you removed was a pressed on bearing. It should have been pressed off to avoid any damage. The "loosesness" probably wasn't a problem. When reassembled the collar with the seal would have stopped the wiggle. New bearing might go on with the chill/heat procedure or rig up a press.
Pic is a bearing seperator. used in conjunction with a hyd. press.
Don't need to weld or fill. The cut probably won't hurt anything?
The loc-tite probably changed color from age.
gica
Hey Jerry so would you reuse it no problem or get another. The loctite was 2 years old. I rebuilt this engine. It was dying at idle when placed in gear and it had play on the upper bearing. The brown is from the play. I bought the loctite 518 and the noodle rubber string. I will probably use the loctite.
But this for sure was the reason it dies at idle when engaged. I had to up the RPM to 1100 to stay on.
Let me know for sure on the crank seat crease if I can use it as is or not
Thanks to everyone for the responses.
The " play " in the bearing means nothing to me.----An actual dial indicator reading would mean something.
gica
My other 120hp has absolutely no play. This one was even making a sound because of the obvious play. For this you don't need a dial it is passed the dial limit for sure. And the fact that the 2 year old Loctite 518 turned brown right at the bearing side
automatically means it had play there. I checked the surface of the 2 halves and they are both straight no bend. I understand the dial need to check it being true. Maybe I should just get another
Crank and maybe that would eliminate the confusion.
gica
boats.net has a good parts breakdown.
Thanks Jerry there are several that do I found really cheap parts at marine engine. The crank was 215 brand new including the bearing on top. The king pin and 2 plastic so called bearings 18 bucks so I got 2. I will do the other engine. I wish I did it last summer when I rebuilt it. Of well I a getting good at removing these things. They are so easy to work on.
Thank God there are still parts available.
