rolmops
- Feb 24, 2002
- 5,672
I am almost done pulling the transom (very sloddily installed 2 years ago) out of my 1989 Starcraft Islander and as usual I ask myself if I should take the big step and remove the I/O and change to an outboard. With the transom being replaced, now would be the time to do it. I'm eying a new 175 horse Suzuki which would sit nicely next to my Suzuki 10 horse trolling kicker. The idea is to get a 25 inch shaft one (the transom on my Islander is 44 inches high). Get a heavy duty outboard bracket, cut the transom 19 inches down and make that cut out wide enough for a main engine and kicker, while also creating a splash box in order to be able to raise the engines, but still have them close enough to the transom.
My cobra engine and outdrive weight about 700 pounds while the kicker is 128 pounds. the Suzuki is about 500 pounds, the center of gravity would move farther backward to the stern. I already moved the batteries to the front of the boat and this will hopefully offset this shift in balance. And the transom will be strengthened in the center with extra supports to the stringers. The new transom will be high end marine plywood 1.5 inches thick and have 25 plies. The two four by eight foot sheets were $185 each.
What holds me back right now is my worry that this change will create vibrations that may create hairline cracks in the 39 year old hull or in the stringers. This boat has never seen salt water and has always been trailered and there is no corrosion anywhere on the hull.
Do you have any thoughts or advice pro or con changing from cobra to outboard?
