1994 Evinrude 50 HP Not Charging
Find a wiring diagram online.----mastertech marine.-----Early 1990's V-4.----Wiring is the same / nearly the same as your 50 HP.
Wreck'D Hunter
Success! Thank you all. Interestingly, the RR allowed the voltage to run up as high as 15.4V before it settled down to a steady 14.4. (V confirmed by digital MM).
Thank you all, and hopefully those coming after me will benefit from this post, and not bother you as much as I did :)
saltchuckmatt
How many RPM's is your motor doing with the volt gauge where it's at in the picture?
dwco5051
If you are truly getting high voltage as measured with a known good meter check all your ground connections including at the battery terminal for loose or corrosion.
