Your Best Technique for Rope Starting Merc 20hp EFI
SeaKaye12
Well....I have a "new to me" 2020 Mercury 20hp EFI that runs 100% but challenging to start. It's not electric start.
If I use a drill it starts immediately.....and it seems to start better if I run the drill slowly. Interesting.
That leads me to think that I should apply the same technique to rope-starting. Long (full rope length) slower pulls. Sometimes works.
Those of you who have these engines.....share your starting secrets? Please? Thanks!
airshot
Carry a cordless drill with you if rope starting is not an option. I have saw guys make mods to there cover so the hood does not need to be removed to use a drill. More noise when running with a hole in the hood though.
boscoe99
Running a drill motor, or pulling a start cord, more slowly is counter intuitive to my thinking.
Pull the cord more slowly and let us know what the result is please.
SeaKaye12
Boscoe; I would certainly agree. Every other motor I've ever had liked to be pulled hard and fast. The harder and faster the better! Get that fuel sucked up where it needed to be.
These four strokes though have a compression release of some sort. I can tell when I spin the drill. At lower RPM there is a different feel. Get the RPM's up a bit and all of a sudden I can feel the compression kick in. Maybe that has something to do with it?
I also find that, contrary to the Owners' manual.....it helps alot if I give it some throttle. Twist the grip to maybe quarter throttle. The manual states that it should be at the fully closed position.
I'm slowly getting a technique that works. I posted to see what other owners of these motors have to say. There is certainly no shortage of forum posts saying that these EFI Tohatsu/Mercuries are hard to start. Of course there is no choke or enrichener. The carbureted versions had one or the other....and the use of that typically would also bump the throttle open a bit in the process.
boscoe99
I agree that motors can be like living animals. Each having their own preferences as to how they like to wake up.
Since your model does not use a battery it relies upon the alternator to generate the electrical power needed by the ECU and the electric fuel pump. Permanent magnet alternators typically create more electrical power the faster the magnets wiz by the stator coils. Which is why the motor starting easier with slower rotation is confusing me. But I am old and get easily confused these days.
Texasmark
Most sparked outboard engines use a rotating magnet on the flywheel passing an iron core coil of wire, anchored adjacent to the flywheel magnet to generate the trigger voltage to cause the spark plugs to fire.
The equation for how that works is V (output voltage amplitude) = [ L (inductance of the coil) x di (actual current change) / dt (period of the change)]. Simplified: V= L di/dt.
Therefore the faster the magnet passes the coil (minimizing the time), the higher the di/dt number x the constant (L) increases the induced voltage output. You are correct in that pulling slowly generates less voltage for spark generation.
Multitude of decades ago, I had a new rig with a Chrysler 85 HP 3 cyl. 2 stroke. I only had one battery and in operating my trolling motor...new rig, first trolling motor, had to learn the ropes.....I ran the battery down. The cover over the engine had a plastic patch on the underside and in the pouch was a cranking rope. I set the controls like I was going to start the engine with the key in the normal manner with the key in the ON position. Put the rope around the slot on top of the flywheel, got in what I thought was a good solid position and pulled as hard as I could.....engine fired right up, first pull, which was easier on me than I thought it would be with an 85 HP engine.
Obviously the moral of that story is to have 2 batteries which I had the next time I went fishing and no more cranking rope starts.
matt167
Pretty sure that’s a battery less EFI which runs directly off a stator. If that has an issue bringing voltage up to the ECU it may cause it to struggle. EFI 20hp should start with one or 2 strong pulls. I wonder if the stator is weak. There are other causes for hard start. But would help explain a slow crank faster start as it would have a longer dwell time with the magnets
boscoe99
Interestingly enough, what is called a stator in some Mercury Marine models is now called an alternator by Mercury Marine for the batteryless EFI models.
The stator being a part all alternators of course.
Mc Tool
:DIf you took that to its logical extreme then aligning the magnet with the coil and then not moving it at all should produce a massive spark . The juice is produced by the movement of the coils thru the magnetic flux and the faster you do that the bigger the spark ....to a point , to slow and you get nothing .
matt167
It’s induction. It’s an alternator essentially. Several factors could be contributing. Even A/C voltage spikes or dirty power after the rectifier. It could have trouble starting as there isn’t a lot of current to go around, but once running there is sufficient charge. The main thing is that spinning slower shouldn’t start easier, and an EFI engine should not start hard
Texasmark
No! I've had small, single cylinder 4 stroke engine prefer a mid range RPM to a WOT throttle position with the same cranking rope pull. The engine has a steel wheel with blades attached.....starting under load essentially on my leave vacuum. I'm guessing the fuel availability is the problem since the problem occurs at the start of the leaf pickup season in the fall.
Mathematics don't lie, nor do physics! The equation describes the event! Supposing something else is distracting to say the least!
airshot
Have owned more small out boards than I have fingers and toes over many, many years. One thing I have learned is each one has it's own method for quick starting. Use logic and try different things and make note of what does not work. With enough patience you will figure it out. Owners manual is a good place to start, but I have owned motors that don't like what is in the manual even though that is rare. Be methodical in your testing, pay attention to things like is there a lack of fuel or is there excess fuel....etc, if the engine is in good working condition, it will start and run.
Mc Tool
The faster the cranking speed. The sooner a engine will start. Hot or cold.
Yeah , you'd think aye .
I wonder if you give it a really good yank (the pull cord ) could you spin it fast enough to deactivate the decompressor before it gets a chance to fire 😁and then hit full compression ,possibly backfire and stop dead 🤔
flyingscott
If it doesn't start in 3 pulls take it back to the dealer, something is wrong.
Mc Tool
I think that was what was actually written in my Dads new (early 70's) Seagull outboard owners manual .
Did you guys ever have them available in the US/Canada ?
cyclops222
Do remember to squeeze rubber ball until firm.
Do turn on the choke if cold enough.
Advance throttle to a little less than 1/4 open.
