Winterization difficulty
R Lowery
Okay, bare with me I am new here and this is my first post.
trying to partially winterize my boat.
I purchased this 19.5' spectrum with a blown 4.3l inboard a couple months ago. I was hoping to have it back together by now, but life happens.
engine is removed, it had a half cooling system, but I am concerned about the outdrive, it is also blocked in the raised position so the prop cup holds rain water.
How do I winterized the outdrive alone? I can probably lift the outdrive with a jack, remove hyd lines, and blocks and lower it. Do I need to pour antifreeze in it?
Thanks
Scott06
Thanks
the outdrive it self in the down position is self draining as long as the drain holes are clear. I spalsh some af in the prop hub to take care of any residual and if you leave it outside you should cover the prop ub so no snow/ice or leaves get in.
If you are worried about a new to you boat pull the drive and store inside until you can verify not crap is in there that will prevent if from draining also can make sure there is no water in the bellows either.
R Lowery
thanks.
it shouldn't be plugged, I took it on the water when i first got it so i could verify the drive worked before teardown. got 39mph with 2 cyl's being pretty knackered. and it spewing coolant from the heat exchanger(headgasket was blown between #1-#3 and pressurizing cooling system).
agree with above
trying to swap a motor with the drive in is 5x as difficult than doing it with the drive off since you have to have the drive off to align the motor.
just drain the gear lube and pull the drive off the boat.
Scott06
yep, never said i was smart, or experienced in boats.
Its much easier with drive off. Taking the drive off seems like a big deal until you have done it. You need an alignment bar to algin the engine and drive when you go back in. Worth looking at the coupler while engine is out as now is time to replace it. Again double check your stingers and transom before you get in too deep.
Was working on a friends boat this summer - fuel contamination. while working on it (2000 or 01 glastron) and notice heavy cracking around outdrive on transom... transom wet and rotten... looks like the swim ladder bolts let water in. So bottom line he is looking for a new boat vs doing bellow and cleaning out his fuel system .
R Lowery
i will be keeping this boat, the 4.3l rebuild is a short term bandaid, i will end up swapping a v8 in, probably an LS 5.7
