Lou C
Thread starter- Joined
- Nov 10, 2002
- 14,630
Ok so all season had a performance problem where the engine was reluctant to plane the boat and max rpm was way low 3800-4000. First I went thru the ignition system & verified total timing advance, then rebuild the Qjet (but no real problems found). Next ran it on the remote tank with fresh fuel and it ran like normal. So that brought me to the boat fuel system. Pulled the pick up tube & antisiphon valve & both were fine. Looked at old fuel line wasn’t delaminated inside. Vent was open. That leaves the fuel, it was e10 fuel stabilized less than a year old. I’m thinking it must be bad fuel since after all that no real problems found! Might have to get the tank pumped. Looked in the tank it looks clean to the bottom. Fuel from fuel filter looked normal. No water, crud etc. Thoughts?
While I was in there I replaced the old pick up tube & anti siphon valve & fuel line. I was surprised it came apart so easily esp since the tank is original 37 years old!
