FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
johnson 50 hp vro has small amount of fuel spraying from carbs . question: could bad reeds be causing this ?<br />need input <br /> thanx , skelly<br /><br />------------------
Re: will bad reeds cause fuel to spray from carbs ?
Yes it is common for OMCs two and threes to spit a little fuel back at you.A fuel restriction or weak VRO will animate this phenomena.What symptoms are you trying to cure?
The symptoms are : idels little rough & small amount of unburnt fuel that drips down leg of motor. Not a lot, just a few drips after each outing.<br /> Thanx Skelly<br /><br />------------------
These guys are right about a little bit. If you can see it when look across the carb with the engine idling then it's too much. With broken or chipped reed you will see it easily.
