Alpha 1 Gen 2 - leak & transom service questions
ShoalSurvivor
1999 Stingray 4.3 - owned since 2013. 216 hours on the meter.
Original bellows (25years); shift cable & cable boot replaced in 2016; impeller serviced regularly; trim sensors have been disengaged and “bypassed” since 2005. Primarily used in salt-water, but well rinsed with Saltaway and dry stored in warm garage with drive down after each use.
She started taking an a little water at end of the season. I was able to see a few drips down the inner transom wall below the Y-Pipe, but could not locate source. Water accumulates when engine is not running. I’m considering connecting hose directly to intake hose and running to see if any water leaks from engine, just to rule out any engine leaks.
Q1: Any reason NOT to run this test, or are there other things to test at this stage?
I’ve decided to tear it down to inspect and perform a transom service, and also replace the trim sensors, but have a few questions.
Drive has been removed. I found NO WATER in either u-joint or exhaust bellows. The gimbal bearing is clean and rotates smoothly with no play. Universal joints are in excellent shape.
I’d like to avoid pulling the gimbal bearing if there is no reason to replace it. (I don’t own those tools). The seal is probably original, but seems to be doing its job.
Q2: Ok to leave bearing and seal in?
Q3: assuming the leak is not affecting the 9yo shift cable, is there any reason to replace it, if no shift issues?
Q4: Is the bellows sleeve reusable, or should it be replaced?
If replaced, and I slice to bellows to remove the bell housing, can I just tap it out of the housing (carefully) from behind? I've seen a lot of chatter about difficulty installing sleeve - any tricks on using install tool?
Q5: Parts-wise, I’m looking at Mercruiser or Sierra for bellows kit, and avoiding the cheap aftermarket versions. Any strong recc on Merc or Sierra (a little less expensive)
Q6: Same question for Trim sensors - Mercruiser or Sierra ok?
Q7: is the bellows tool needed for Gen2 with the sleeve, or can it be finagled on?
Q8: should I replace the shift shaft busing with the new dual seal bushing while I have it apart?
Thank you!
tpenfield
I'd be finding the leak first as it may impact the rest of your planned work. I would think you could run the engine on the 'muffs' to determine if the engine is leaking.
Keep in mind that when the boat is in the water, the exhaust bellows is full of water as is the lower portion of the Y-pipe.
The leak could be at the transom or even the Y-pipe.
Use your phone or even an 'inspection camera' to find the leak. Guess-work does not really get you very far.
ShoalSurvivor
best I could tell, the drip was accumulating at the base of the y-pipe. I searched to see if it was above that point and running down but could not see or find any other source.
i already pulled the drive for impeller service and figured I’d inspect the bellows while I was there, and thats when I decided to tear down farther and get the transom and trim sensor work done, which I have put off for a while.
I agree with finding leak first, but since the drive is drained and removed, muffs or lake test aren’t an option, which is why I am considering the direct hose connection.
Wouldn’t that help me isolate engine leak and all other transom entry points (except the intake hose, exhaust bellows and y-pipe?
after more research, im now gonna focus on the y-pipe. Could be corrosion, gasket or bolts. I replaced the exhaust manifolds last year and flappers were in good shape. I inspected inside y-pipe for corrosion but didn’t see any. I Will check for loose bolts, exterior corrosion, run and check for gasket leakage.
Pmt133
I had a leak after rebuilding my boat and resealing the transom that drove me crazy. It ended up being the shift cable bellow that was damaged from new. It is hard to see without a camera but mine looked like the y pipe leaking as well and was always worse running. If you decide to do the gimbal, you can rent a slide hammer at any auto parts store then when done you bring it back and get a credit on it. That being said, if it isn't making noise and its a greasable bearing... just leave it.
Since you're going through the work, I'd replace the shift cable but thats just me.
I only reccomend merc at this point. Sierra on my last job lasted only like 6 or 7 years while the merc went nearly 20. The price difference at the time for the full kit with bearing was less than 90$.
I haven't had trim sensors... well my entire life. But again, I'd go merc as that job also sucks.
Grub54891
Mine was the trim hose gasket on the very bottom of the housing. Bellows and made sure it was all good, put in water and leak still there. New gasket cured it.
View attachment 412921View attachment 412922
Thank you!
Ayuh,..... #2, Sure, no problem,.....
#3, sure, no problem,....
#4, No, if you remove it, replace it,.....
#5, Mercruiser/ Quicksilver only,....
#7, If you spray quicksilver "Power Tune" all over the area, you can slip the locking ring in with yer fingers, no tool needed,.....
ShoalSurvivor
Thanks for your responses.
When running with hose connected to intake, please verify that I should start it first, then turn on water (to avoid forcing water through the block) and turn off water before killing engine.
Thanks
Scott06
if the Y pipe was leaking and you stick a hose in bellhousing the water should go through the engine and leak out the Y pipe, engine running or not.
I think the places above the Y pipe that could leak are driveshaft bellows, water in pipe fitting, steering shaft seal. Not sure if shift bellows or oil line to drive could leak there.
You may have to reinstall the drive get a scope camera and put it back in the water to figure it out. These can be really difficult to figure out.
Any chance the transom is rotted and leaking around the gimbal housing?
Per your other comments no the sleeve holding bellows to bellhousing is not reusable, generally it gets beat up taking it out. To put it in I used some pieces of PVC storm drain fittings I had laying around that fit the OD of it and used a BFH to push on it. Power tune helps as lube to slide on the bellows. I found this easier if you have a helper, I had to keep the bellhousing parallel to gimbal housing to keep the bellows from sliding out of the bellhousing ( I think there is a lip in a groove). Also yes ok to keep existing shift cable. Mine shifted so good when I replaced the bellows (2004 boat) 3 years ago I left the cable as I didnt want to mess with it.
I would stay away from sierra senders as I "saved" a few bucks using them and trim gauge never really worked right. On that bellows and impellers I have found the OEM parts to be worth the money in longevity and fit.
ShoalSurvivor
Ok, plan for today:
1) hose in Ypipe to see if leak appears
2) if yes, then check for loose screws and see if tightening them resolves leak
3) also, inspect ypipe and transom for source and/or corrosion (leaking or not)
4) order inspection camera, drive gasket; transom service kit, sleeve, shift shaft bushings, and gimble pivot tool for future use.
question: i can snake a camera in the ypipe to inspect. Should I be able to access the two smaller transom ports from inside y-pipe, or would I need to pull the bell housing to access those ports?
next steps: reinstall drive for day of harbor leak detection fun With inspection camera
next: tear down bell housing to inspect transom mount, and all protrusions.
next: blaster on engine mounting bolts.🙃
Bt Doctur
remove the drive and plug the relief holes .drain and remove the risers, fill Y pipe with water to see if it leaks inside the boat
ShoalSurvivor
Results:
Plugged small exhaust ports, ran hose into Y-Pipe. NO LEAKS
YPipe bolts appear tight. Used a tap hammer to inspect the YPipe and transom and found no soft or hollow spots.
Next step: reinstall drive, get boat-leak-o-scope and take it to the harbor.
ShoalSurvivor
I was on the right track... I could hear the water level about 1/3 of the way up the risers (I finished my test just minutes before you posted :)
I am gonna scope it in the water next to look for exact source location, and then return to the YPipe/Transom teardown after that.
thanks!
ShoalSurvivor
Drat! Water appears in bilge, days after test.
I serviced the impeller, installed the drive, and filled with gear oil, with the intention of taking it back to the harbor for an in-water inspection with camera.
Today, I found water in the bilge, presumably from my removed-drive, hose in y-pipe test. I could not see any active drips during the test, and it seemed that all the water exited the pipe/bellows immediately after removing the hose... so I'm a bit bewildered as to where that water came from.
while it could be any of the intrusions above the y-pipe, this seems to points to Y-pipe mounting or corrosion, yes?
ShoalSurvivor
UPDATE: Dropped her in the harbor and found the leak in lower transom assembly area where trim hoses penetrate. I could not see where the actual leak is, but this area fills with water, about 3ozl per minutes, then drips down the inside of the transom. I tried to suck the water out while submerged to get a video with my inspection camera, but it filled back up almost immediately.
Here's a photo after I drained and dried it out. It's behind, and under the YPipe, and very hard to reach.
Is the hose penetration serviceable after removing the bell housing on the outside? or, do I need to pull the motor to get to this repair?
Looked just like this:
Link: YouTube of someone else's hose leak
I also have a front camshaft seal leak which I am planning to fix, as well, but I can probably reach that by pulling the rear sear (though obviously easier if the motor is out).
thanks,
Michael
Grub54891
Have you checked the gasket on the trim manifold at the bottom of the gimbal housing? That’s where I found my leak just like that. I had enough room to remove the lines after I unbolted it from there. Really Not to bad of a fix.
Scott06
thanks,
Michael
there is a gasket under the manifold, drop it down from the outside and you can disconnect the hoses as they should pull down with the manifold.
then slide on a new gasket, look for any corrosion if salt or brackish use
By camshaft seal do you mean the timing cover is it leaking where it meets the oil pan? If so there is a thread on here where one of the guys ended up replacing not only the timing cover but also I think the oil pan as GM had same manufacturing flaws w the flange where they meet. I think GM updated their cover or pan design. Bottom line the guy had the engine in and out several times to fix the leak
nola mike
That can also still be a rotten transom. Bolts holding y pipe can corrode on the bottom.
ShoalSurvivor
If this is the source, should I expect to have water spill out of the manifold when I remove it? just setting expectations. thanks.
I have new bellows, trim sensors, etc. and was planning on replacing all of that anyway. I suppose it would be easier to do the manifold work, when I service the bellows. However, if the leak is through the manifold, I would like to test it BEFORE doing the bellows work and/or pulling the motor for the oil leak. One step at a time ;). Does this make sense, or should I just pull the motor, do the oil leak repair, replace the bellows and sensors, manifold and hoses, then put it all back and just hope for the best?
