Tohatsu
rbronston
Hello I have a tohatsu 15 hp . After about 10 minutes of running it bogged down. Then I have to pump the bulb again. It will run the bog down again. This continuous. Any idea what the problem could be. I got a new hose and it is still doing it. Thanks
redneck joe
Sounds like the tank is not venting. Try running with the cap off. Im assuming it is a portable tank and you have already ensured the vent screw on the cap, if it has one, is open.
rbronston
Hello I have a tohatsu 15 hp . After about 10 minutes of running it bogged down. Then I have to pump the bulb again. It will run the bog down again. This continuous. Any idea what the problem could be. I got a new hose and it is still doing it. Thanks.
So far I changed the fuel filter. But now I went out it still did t he same thing but even worse now it wont start at all.
redneck joe
So it did start and run after filter and now nothing? Try a few squints of fuel directly into the cylinders and see if goes.
