saltchuckmatt
- Jul 19, 2019
- 3,397
Wet or dry would give indications on where to lookNo, I have not simutaneously while starting but I will try. I'm usually alone when this happens so I have tried pumping the primer ball then going back to the console and turning the key. It's typically soft (but not collapsed) when I first grab it, and then it gets firm right away. I'll take a look at the spark plugs the next time I can work on it. I assume what I should be seeing is that they are wet, right?
Edit: also I plan to run a test this weekend, disconnect the fuel lines and splice them to a clear line running back to the fuel tank. Disconnect the starter +. Crank and check for air bubbles and decent flow, including the primer circuit when the key is depressed.
I had originally notice that you weren't setting the high idle before starting so possibly a flooding condition or spark is your problem. Spark plugs can tell a story.
