Mercury 3.5hp 2012 outboard hard to start due to over compression? Cause? How to fix?
papatango
Looking at another thread here on iboats (https://forums.iboats.com/threads/3-5-mercury.777945/#post-5966759), and doing research online I have discovered that this motor has a de-compressor? Where? How to fix? Mine is very hard to turn over. I originally thought it was a valve timing issue, but the valves are driven by direct gear off the cam shaft. I took off the oil pan after draining the oil as it was due for an oil change anyway, and the cam shaft timing mark I found aligned with the gear shaft timing mark. The rocker arms and valves appear to be ok, nothing stuck. Using a feeler gauge the exhaust valve appears to be slightly tight at 0.1mm instead of between 0.11m and 0.19mm. I had actually thought it was much more out of spec days ago but I had mistakenly measured the gap. A second measurement showed me it was only slightly out of spec.
This all developed in front of my eyes one day while testing in a test tank about a week ago. I started, it was running at idle, in gear, purring along just fine. I throttled up a bit and it sputtered and died. I suspected the fuel pump, but wanted to open the gas cap first, but never got the chance. I could not restart. I pulled. And pulled. And pulled. And gave myself tendinitis. I also observed what appeared to be back firing or back-flow of air out of the carb while attempting to restart that I had never noticed before. Little puffs of air, sometimes sooty in appearance. I have no idea if that’s normal, but I doubt it. Eventually the motor quasi-hydro-locked on me and tipped over toward me quite a bit during one pull. Pulling was met with such resistance that I could not overcome sometimes. It would just jam. I removed the spark plug, which was also due for replacement anyway, and it was fairly black, but not encrusted, nor wet with anything. I cleaned it up a bit with a toothbrush. I have a new one but that one is still in the box. Ever since that afternoon, and it’s been over a week, I cannot turn the flywheel except with great difficulty on the compression stroke, unless I remove the spark plug. Without a spark plug, the flywheel and everything moves smoothly. I also think there is some new resistance due to my need to overcome a vacuum before the intake valve opens but it’s not as strong as the over compression.
I thought this motor had no cam shaft de-compression mechanism of any kind to assist starting. Looking at the service manual, I don’t see any reference to any kind of de-compression mechanism anywhere. I hope I have the correct manual: https://media1.svb-media.de/media/s...10-59-17_2cd641e2bd2fc2a699804065d133ada4.pdf
The valve timing is not adjustable. Nor is the ignition timing. It was possible that on that day I got too much fuel into the cylinder and that caused a quasi-hydro-locking situation, but it’s been many days since then, and many of those days I left the spark plug off the motor, so that gasoline is long gone. I am stumped why it’s so hard to pull or how to fix.
I have not adjusted anything yet. I have only drained the oil and removed the pan and since put it back, and peeked at the valve rockers, piston rods and cam shaft via the oil filling port. I did remove the head from engine and removed the pull starter so I could examine this indoors on a bench. I bought a feeler gauge and am looking into getting a torque wrench and bore scope to help me out here. I don’t think the flywheel is involved, but I haven’t remove it to check for shearing. Don’t see how that could be involved in over compression. I still suspect as I originally did that the valves are not opening and closing at the correct times unless there actually is some decompression mechanism that is failing me. But I know the valve timing is not adjustable, correct, and direct gear driven by the cam shaft. I also know hydro-locking is impossible at this point. I considered maybe there is carbon build up in the cylinder? But without a bore scope I cannot tell at present.
I should mention I had previously cleaned the carb and it is certainly possible I flooded the engine while trying to start it again in the test tank from all the pulling. But what is so strange is that it was working, then merely pulling ok but not starting, and then from one minute to the next, hard to pull at all.
And I just detached the fuel pump pulse hose from the intake manifold. But this does not help at all. I still have a lot of compression resistance. Covering the manifold intake while manually turning the flywheel I can usually feel vacuum on the intake stroke but instead I hear air being sucked in via the detached hose. Otherwise I left the fuel pump attached to the side of the motor, but minus the fuel tank obviously.
Any advice would be welcome. Thank you.
airshot
Turn it over with spark plug removed.......does anything blow out ? Is it still hard to pull ??
boscoe99
There normally no over compression. It is just that normal compression makes a four stroke motor hard to pull start. A decompression mechanism momentarily prevents full compression when a starter rope is pulled.
papatango
A week ago I did not notice anything blowing out. Today nothing blows out. And it is easy to pull without the spark plug. It is hard to pull with the spark plug. Lots of resistance during part of the cycle.
papatango
I understand that but the normal compression appears to have increased dramatically and is sometimes so hard the motor will tip over rather than the flywheel rotate. I think that is proof enough something is wrong.
boscoe99
If the compression release mechanism is not working that might fool someone into thinking the compression is excessive.
papatango
So where is the compression release mechanism on this motor? I don't see it. Not in the service manual, nor on the cam shaft. Where else to look? What do I look for? Does it even have one? How to fix? Etc. Those are my questions.
boscoe99
I don't know personally that your motor uses a decompression mechanism. My comments were based on you saying that it has one.
Have you thought about the possibility of a lower unit problem causing the motor to be difficult to pull start?
Easy enough to remove the lower unit and then use the pull cord.
papatango
I had it in neutral. And, as per my original post, I already removed the power head and have it on a bench, ie, the lower unit is not attached to the power head. This is in no way a lower unit issue.
cyclops222
I went to the company website. NO WHERE is a compression release mentioned. NO WHERE. Call the company or a dealer ?
boscoe99
Something leads me to believe that the gizmo seen on the cam shaft for a Mercury Marine 3.5 four stroke model is related to the compression release mechanism.
cyclops222
The compression reducer is normally only functioning during very low engine speeds. Such as rope hand starts.
I went to JLM site and read a detailed parts list. Could not find any words like compression release. About any parts.
cyclops222
Have you VERY carefully checked that the intake and exhaust valves are opening and closing fully with the spark plug removed ?
papatango
I had the very same thought recently as one of the few possibilities left to consider. I certainly saw the rocker arms moving. Perhaps they are sticky and slowly open or close? I will take another look soon.
papatango
I also saw that gizmo in the flesh... or in the metal... I have no idea what it does. It does move slightly. I can manipulate it slightly with the end of a pencil. But it appears totally connected to anything mechanically. I suppose I could try to fix it in one extreme position and then the other while yanking to see if I observe any difference in behavior. AI is definitely not the way to go here.
papatango
Totally *unconnected*
papatango
I did again and as far as I can see the valves are opening and closing just fine. The rocker arms move up and down, and the valves do too without any hesitation or noticeable stickiness. I discovered also that I can see most of the push rods too and these appear not to be bent in any way. If there is any carbon buildup on the valves I cannot see it at present b/c I would have to tear down the entire motor or I would need a bore scope.
