redneck joe
- Mar 18, 2009
- 15,991
Good point but still question the flex and forces when being operated as compared?
Most savers that I have seen, have a spring loaded or a snubber that has some give under severe stress, yet keeps motor from flopping around. you don't want the motor to flop up and down, yet some kind of give or control in a severe situation. It is the constant flopping up and down that causes severe issues.I’ve already bought the transom saver and installed the mounting bracket. I wanted to make sure I wasn’t causing more harm by using it at this point.
you're notI’ve already bought the transom saver and installed the mounting bracket. I wanted to make sure I wasn’t causing more harm by using it at this point.
Roads aren’t too bad around here, but I doThe roads here in my part of Pa. are pitiful. Transom saver all the way.
