454 mag mpi chuggles/stalls
Fun Times
You mentioned a new long block and the previous engine had the same issue. Did the intake manifold come from the old engine to the 'new' long block? (sorry if that was already discussed)
This question on post 61 seemed to go unanswered...?
As in some reference, is item numbers 2 and 3 in place?, https://www.mercruiserparts.com/bam/subassemblydetail/37744147/28149300
Check the vacuum lines that connect to the fuel damper/regulator at the back of the fuel rail, port side of engine. There should be no fuel present in the line
That damper can fail and cause an overfueling/rich condition at idle. It will be evident by checking for fouled spark plugs
If this is indeed your cause, the damper is nla from merc and GM. In the past I've plugged the damper vacuum connection and the vacuum line at the damper to solve the issue
Also post 13 needs attention.... Is there gas in the vacuum line / coming out of the fuel regulator? See hose A / 46, https://www.mercruiserparts.com/bam/subassemblydetail/37744147/28149300
Also in one of the videos above, the flame arrestor (#38) appears extremely black and dirty, have you cleaned it? ran the engine with it off and/or another one when you swapped plenums? Hope the engine isn't starving for air.
One sensor wasn't physically mentioned as being swapped out and tried but I suspect it was tried with the swapped out plenum is of the MAP sensor itself.
Have you tried a new/another used MAP by itself? I saw you unplugged it, etc. but have you inspected the MAP seal too (Item number 20)? They become compromised.
This may sound dumb but in the past I had found 2 bad MAP sensors by accidentally putting/resting my forearm down on the top of the (454/502 MPI) map sensor while the engine was running and found the particular issue the engine was having as the weight changed the engines behavior to normal... Try touching the MAP sensor...
Try swapping item number 17 just because, https://www.mercruiserparts.com/bam/subassemblydetail/37744137/28149300
Engine temp is reaching 154 degrees minimum? I saw 132.8 in one of the posts above not answered.
Item number 18 in place, https://www.mercruiserparts.com/bam/subassemblydetail/37744139/28149300
vroom ZOOM
Yes, the intake came from the old engine, and that is the only part I have not tried moving from the other engine, aside from the transmission. I will move it over today.
As for parts 2 and 3 there isnt even a hole for them in the intake.
No fuel in the vacuum line to the regulator.
Flame arrestor wise, the other engine runs with either or. I tried swapping them to no avail. I can see light through both so they should pass enough air to idle. If they were restricted I would see a very high vacuum as the engine starves for air. definitely not the case here.
Tried a new oem GM map sensor and tried the one from the other engine. Also tried swapping the distributor jumper harness.
That little connector (#18), where does it go? I do not recall seeing one.
vroom ZOOM
Weird update #102380703023!
Today, I swapped the intake manifold between both engines as that is the ONLY part I have not tried. Put it on and the engine started then quit. Unplugged the coolant sensor and it did much the same as before.
*Flashback from a couple of months ago*
I remembered another boat I was working on (just an old carby setup) with a pertronix module. On that thing, after installing a new module the timing was WAY out of wack. After turning the distributor it just randomly started loosing spark. Turned the dizzy back, and the spark came back (but really out of time). Without another thought, I moved each wire over one post and then the thing was close enough that I could time it up and make it run just fine.
*end of flashback*
Well, I decided to try this same thing here. Turned the dizzy way over so the rotor pointed at the next post, then moved the wires over. Also while messing around I realized I had unplugged the hose to the outboard tank I was running it from. Plugged it back in, purged the air from the rail, and tried to start it. It fired a couple of times but quit pretty soon as usual. I removed a spark plug, and I was OVERJOYED to see it soaked in fuel... This engine finally had too much fuel instead of not enough! I plugged the coolant sensor back in so the engine would stop dumping fuel in, and it just started.... and stayed running. No missing, no IAC hissing. just running.
I shut it off and started it again and it ran good again. I don't know if it will start tomorrow, as this engine has been a bunch of curveballs, but we are making progress.
My only theory here is that I somehow changed the time at which the injectors fire relative to the intake valve opening and that helps it take on more fuel... Which is kind of silly considering the sensor in the distributor does not know which cylinder is at TDC and this engine uses a batch fire system. super weird.
I am sitting here thinking if it was the intake manifold swap that did the trick or if it was the distributor...
alldodge
Glad to hear your running, but have issue with the cause
vroom ZOOM
WELL....
My problems didn't stop from the last post... Far from being trouble free.
After doing the dizzy turny wire swappy thing that made the engine run like BUTTER, it ran good the next day too. The day after that, it ran good again, so I decided to finally take the boat out for a test run and take on some fuel. Well, I cranked up the engine, ready to head out for a test, and it went back to square one.
Damn, I was PISSED. However, I realized that if I give it some revs to keep it running for 30 seconds or so that was the required amount of time to get it to push the IAC full open. With the IAC almost full open it would stay idling without stalling and let me go in and out of gear. The engine sounded like crap and was clearly misfiring but I decided to go ahead and see what would happen if I got on the throttle. So I took the boat out, and as soon as I got past 5% throttle the engine would run excellent, no misfiring. Back to idle and it would miss.
Ok, whatever, it runs good on plane, and fall was around the corner, so I decided that the engine should get me from Annapolis all the way up to Canada, and then I would mess with the idling issue when I got the boat home. First day, did about 80 miles uneventfully. Next day I wanted to do even more but the sea was very rough past Cape May so I had to take the ICW. Then I ran into the Dorsett Avenue drawbridge in Ventnor city that was broken and wouldn't open so I ended up doing about 95 miles that day. The next day I did some shopping in Atlantic city as I had lost my barbecue in the Delaware bay, the chop caused the barbecue to rip out of its post on the swim platform. Waited for low tide, removed everything from the radar arch, and managed to squeeze under the bridge with about an inch of clearance. Whew!
Did only 40 miles or so that day, and basically got up to Barnegat bay late in the evening. The next two days I was just moored waiting for good weather, and then with somewhat tolerable ocean conditions, I headed out to make the final run to NYC. I was a third of the way there and then I heard a loud ROD KNOCK 🤬! Only thing is that it was coming from the STARBOARD engine, that never gave me any issues. Limped back to the place I moored at on one engine, and had the boat hauled out. Checked the compression and it was kinda missing in a few cylinders. I rented a uhaul van, took both engines out and headed back home to Canada with them. So now I have two bad engines 😭.
I do have to mention that I did the cylinder heads on the starboard engine (the one that was problem free), since a couple of cylinders were a little low on compression and these engines are known for dropping/sticking valves. Had the seats, guides, and seals done on them. Also converted to adjustable rockers so I can manually set the preload.
Well, I tore the engine apart a couple of weeks ago, and the cylinders and bottom end looked absolutely pristine. Not a scratch on any journal or bearing. So I doubt that the knocking noise would come from the bottom end. The pistons and cylinder walls are in good shape too. The only place I could loose compression is through the heads, so I took those back to the machine shop. Got a call from them and they said the thing got extremely hot/lean and warped the seats and guides and they wonder how it even ran at all.
What a head scratcher. It never misfired or anything, but what both engines did was blow a fair bit of steam from the exhaust. Neither overheated, but the exhaust water did get quite warm. I did go through the entire cooling system, and all the pickups, strainers, coolers, heat exchangers were clear. I also installed new exhaust manifolds and elbows. Even at idle, the water discharge from the exhaust was like a fire hydrant, so I assumed the steam was normal. IMG-20251024-WA0000[1].jpg
Well, maybe it wasnt and was telling me something was wrong. I don't know. I also don't know where the heck I am going with this post, but anyways, I have the port engine home right now on a pallet, and I will try start it outside of the boat and see what it does.
vroom ZOOM
okaaay... And I am back to messing with these engines. Seriously, if I had the $$$ I would go with 8.1s at this point. Always my bad luck with a MEFI motor.
Anyways, I put together the starboard engine over the winter, it should be good to go. I then went back to messing with the troublesome port side engine. I hooked up the outboard tank, and started it up on the pallet. Aaaannnd... same problem, lean at idle. I think I can now confidently eliminate the rest of the boat for any issues. The fuel pressure would always drop after the pump turned off after priming, and I had a new spare fuel pressure regulator kicking around on the shelf, so I threw that in but of course that didn't do anything.
Then I took out the oscilloscope again, and put the current clamp on the fuel pump wire. I get a constant waveform, no dropouts that could indicate air bubbles. I also scoped the REF HI wire from the distributor, and I also bought an ignition secondary capacitive probe and put that on a few plug wires, no evidence of anything abnormal.
My plan is to now put a piece of clear hose between the FPR and fuel filter return to see if I maybe am getting very small air bubbles causing the whole thing to go lean. If that doesnt show anything, I will build a special tool that isolates the injector circuits while the engine is running so I can indepentently check the injector waveforms.
vroom ZOOM
Wonder if you have 1 or 2 leaking injectors
Sorry should have been more clear, the new FPR solved the issue of the fuel pressure slowly dropping after the engine turned off, it just didn't solve the initial issue.
Lou C
2 four-barrel carb manifolds
2 Edelbrock 4bbl carbs
2 simple low pressure electric fuel pumps from Michigan Motorz
that would be my solution, no more sensors that can have intermittent problems, you will have the simplest set up that worked 65 years ago (when they were Carters lol) still works now, or if you know and like Holley carbs, that's another option.
Marine EFI, works great till it doesn't, then it's no end of troubles. Think of all the added points of failure....and as you saw some parts just aren't made anymore, you will always be able to find whatever parts you need for a modern Edelbrock carb, or Holley carb, or even a Quadrajet that hasn't be made in 30 years.
vroom ZOOM
Yeah, I thought about that a lot of times. Unfortunately I need to sell the boat, so for a boat getting listed for a bunch of money, things have to be proper, I don't think a buyer would understand a carburetor on there :(
Last time the engine ran well was when I turned the distributor and moved the plug wires over to the next post. Then I decided to put the clips on the fuel injector connectors that I had removed for testing and that messed it up again. The only change in run quality was when:
A) I put in the cheap aftermarket injectors
B) moved the plug wires over one post
C) installed the injector clips
It seems like I am changing something at the top of the engine when I do these things. Oh, and by the way, they are not repeatable. I just cant put my finger on what it is yet. I have a couple more ideas on what I can test with my scope today though. I will try scope the MAP and TPS, maybe they are putting out blips that won't set a code but will mess up the fueling and they happen so quick that the data in diacom doesn't refresh fast enough to show them or for the ECM to set a code...
I kind of want to already develop my own STM32 based ECM to replace the MEFI and have slightly better fault and misfire detection and optional closed loop control. Maybe its a project for next winter LOL.
Lou C
If a guy can't operate a carbed boat with an electric auto choke, new carbs, etc, then maybe he should not be in command of a twin engined boat!
Having been inside all 3 I think the Edelbrock, while not as tunable, is the easiest/least trouble to keep going, reliably.
15-20 year old marine EFI at least from Merc and Volvo, is just not 100% supported, and sooner or later, it will bite you. With carbs, yes you will have to clean and rebuild at some point but compared to what you went through with this, child's play. Auto shop 101 circa 1966 or so.
Once you've done it a few times, really hard....this one is 38 years old now....
I have spares too....
vroom ZOOM
Well, did some more testing. I scoped the TPS and it has a weird blip every now and then where the voltage drops to 0.16v, the rises to 0.7v. It only lasts 42 microseconds, so I don't know if that matters or not. I put some resistors in instead of the TPS but that didn't change anything.
Then I pulled the spark plugs and they were all wet, oily, and with some brown crusty stuff on them. I was expecting dry and bright white spark plugs since it runs better with extra fuel. But no. Super strange. I then did a compression test and the cylinders were all 155-165. Not amazing for something with 20 hours or so since overhaul, but not terrible.
Also i did a cylinder drop test, and there is no difference between cylinders.
  • 20260427_153048.mp4
alldodge
If all plugs are like that one looks like your rings need to seat
Oil rings put in correctly
Fun Times
That flame arrester appears dirty or oily too? Might want to remove it, clean it in say a solvent tank if possible, wash/dry it and clean the throttle body and TB plate too. Inspect/clean the pcv valve/breather hoses.
Either I missed it or don't remember but what are the updated fuel psi readings at?
vroom ZOOM
Well... I made some more progress... for those of you who are just plain curious how this ends up, here is an update:
Everything was still screaming LEAN. I decided to go back to the basic reasons for not getting enough fuel again in a speed-density system:
- Water in fuel
- Air in fuel
- Low fuel pressure
- Low injector pulse width
- vac leak
- clogged injectors
The first 5 checked out fine again, leaving me wondering if I my injectors were clogged again. I don't know if I mentioned, but I did have a real head scratcher boat last year. I had the injectors cleaned, but the guy that cleaned them was adamant that they were already clean. But, for some reason that boat ran excellent after the injector cleaning - for an hour. The next day it was lean again. It turned out that the fuel filter I was given got cross-reference incorrectly, it was just a strainer instead of a filter and would pass through particles not visible to the naked eye, but enough to slightly clog the injectors. That one took me a while to figure out.
Which is why I now I started second guessing whether the injectors in my boat are clogged. I pulled them off again, and just backflushed them with mineral spirits. Well, guess what, the engine ran fine. I was really excited so I sent them out for professional cleaning to a different place this time. Installed the cleaned injectors, engine started and ran fine for a minute or so, then acted up again.
At this point I figured there was some kind of junk, maybe a fuel line deteriorating or something after the filter that was sending junk to the fuel rail. Only a few days ago did I notice that the engine was no longer hissing as it used to when it was lean and misfiring. Which means only one thing - IAC!. Unplugged a vacuum hose to give it more air, and boom, it idles fine. So with my amazing luck the IAC died 1 minute after I put the injectors in.
Now I will put a new IAC in that I have kicking around somewhere and see if I can finally get this engine to run properly. Going through 30 locks on one engine is not fun, and I have 30 more or so, so both engines running right will be welcome!
Hope you all are enjoying the story of my struggles!
