Swap mercruiser 5.0 for a 5.7
Usedvideo
Any tips for an engine swap. I have a good running 5.7 alpha 1 thunderbolt from 1989 to put in place of seized 5.0 thunderbolt from 1991.
Working engine was paired with alpha one gen1
The hull I want to put it in has an alpha one gen2.
Both carbureted,
Will this work?
Thanks
MBAKER
I did this a few years ago in a 2000 model but would expect it to go the same for you especially if you have the same intake setup. I swapped carburetors on mine so I had to work on bracketry and fuel lines but it was easy and everything else bolted into place.
Scott06
Both carbureted,
Will this work?
Thanks
yes zero issue keep the gen 2 drive and transom housing 5.7 should drop in
