redneck joe
- Mar 18, 2009
- 15,987
What kind of boat
What? This is too hard to follow without punctuation.now i have a question i was going to replace the foam when i do the floor and the floor is only soft in one area in the back and i was just going to only replace like a 8 long peice of the floor up to area by the wheel and leave the front but replace the foam in the front to from trying to squeeze underneath the front . i guess my question is should i just replace all of the floor or do it where i dont have to remove the bow seats and the wheel etc ?
i was just thinking about replacing only a like 8 ft peice of floor essentially. instead of the the whole floorWhat? This is too hard to follow without punctuation.
ok yeah i figured i would have to .If your gonna redo the foam, replace the whole floor. Piecing rarely works.
no none as far i knowYeah all of it. Any leaks?
And....if it ever needs replaced....so much easier to pull it out than having to dig and scrape !!I use closed cell foam sheets from H D and Lowes for decades. Cheap and cuts easily on the table saw or Jig Saw.
yes i mean i have only had the boat out on the water 1 once i just boughtSo the water is from rain and wet swimmer people ?
ok sweet anything special i need to know about using it ?I use closed cell foam sheets from H D and Lowes for decades. Cheap and cuts easily on the table saw or Jig Saw.
Have you purchased any lately? The stuff is worth more than it's weight in copper now.Cheap and cuts easily on the table saw or Jig Saw.
No need for saws, box cutter and snap it like sheet rock. Come in diff thicknesses so you can custom fit.ok sweet anything special i need to know about using it ?
I'm in the same 'boat' on a motor i bought for 400 bucks. Aftermarket stops at about 40hp unless go crazy custom which costs. I an buy a used off ebay for about 1200 but do is that juice worth the squeeze? Its got a whale tail on it so id prob just live with it for in between hole shot and top end. I am not after performance just a bit more hp.Also i have a question for y’all my motor now doesn’t have trim. and i was thinking maybe along the road adding a aftermart trim plate. do any of you have any experience with those . and if so do you recommend them ?
