454 mag mpi chuggles/stalls
alldodge
Your thread at Marine Engines list you swapped the ECM's and harnesses and there was no change. Swapped complete intake with all sensors and no change
Everything on the new motor works fine on the old motor, and everything on the old motor has no effect on the block motor. Prior to new long block, that motor was doing same thing as this one.
You say long block, so the new motor comes with new heads?
Are you using new intake gaskets for each swap or reusing old one?
vroom ZOOM
BTW - I had to Google "chuggles" . . .
"Chuggle" can refer to two main things: a type of dog breed or the act of drinking something quickly. As a dog breed, a "chuggle" is a cross between a Chihuahua and a Puggle (itself a Pug and Beagle mix)
Perhaps your engine is 'drinking too quickly' . . . :LOL:
I dunno... this is what mercruiser calls it... straight from the manual!
vroom ZOOM
Have you checked ALL / each sparkplug to see if some are different ? Like the start of a head gasket starting to leak ? Been there and hated the random problem.
took them out, looked a little sooty but all the same.
vroom ZOOM
I only swapped the upper part of the intake with the sensors and throttle body. And yes new gaskets if any were torn.
No parts swapped had any effect, except for the injectors. Today I decided to try swap injectors again. What do you know, the engine fired up and ran perfectly for about 2 minutes, then it slowly got worse and worse until it quit. At this point I am thinking maybe I have a defective fuel filter or something. It ran good for a while before, but that was off the remote tank, and I must have not run it for very long after connecting the boat tank, thinking it was fixed. I will try put the injectors back in the other motor and I hope the other one wont run which would indicate i have found the problem.
alldodge
ok, your swapping the intake plenum not the intake
Still don't think it's fuel, more intake leak or temp sensor
Place voltmeter on intake sensor wire feeding ECM. Note voltage with key on motor off. Start motor and note changes if any
tpenfield
It would be good to have the Diacom connected and recording when you do these tests. Lots of folks go through endless frustration swapping and throwing parts at MPI engines.
vroom ZOOM
I have a rec file. Will send it to you via pm
vroom ZOOM
Put the voltmeter on the tan wire from the ECM with the IAT unplugged. Started the engine and the reading stayed around 5.2 volts. Also wasn't able to get the meter on the wire with the sensor plugged in but here are the diacom readings from the sensor with the engine running. ECT sensor paints a similar picture, just a little warmer obviously.
alldodge
Was looking for water temp and forgot about your diacom. Motor started, air temp went from 119* to 118*, and then motor died, correct?
vroom ZOOM
Yes, I guess the temp went down a little as it started pulling air through the plenum.
vroom ZOOM
well, started doing stupid stuff cuz thats all I have.
Swapping the fuse cube
swapping the starters
running the engine directly off booster cables to the battery
checked the lifter preload
tried wire harness swap again
tried distributor swap again
tried swapping spark plugs from one engine to the other
even swapped the entire fuel system
No luck
One thing I noticed is the spark plugs are a lot more fouled than on the other engine. That is the only clue so far...
dubs283
See post #13
The L29 mpi used two different styles of injectior rails, one cast (triangular shaped) and one stamped (one piece covering both sides
The stamped one is a GM oem part with a fixed damper/regulator that is not serviceable and may be the cause of your issue (running rich, especially at idle)
vroom ZOOM
See post #13
No damper. This is a MAG, not an L29. Serial number is 0L394105, sorry for not posting it earlier.
vroom ZOOM
Did more troubleshooting today. I think at this point I am starting to consider some kind of issue in the transmission. it is a velvet drive 5000v. Is it possible for it to fail such that it somehow tries to engage forward and reverse at the same time and stalls the engine out?
alldodge
Don't see that happening, is the fluid dark and burnt odor ?
nola mike
I've been following this thread just because of "chuggles". Love it.
vroom ZOOM
Well I am completely pulling my hair out. Will call the place I bought the motor from and see what they have to say. Its fair to say I have tried every single part from the other engine other than the longblock and it still wont run. I also tried removing the mufflers to see if there maybe was some kind of blockage, but no, it looked clear.
kd4pbs
You might want to hook up a fuel pressure gauge just to watch what the rail pressure is doing when this happens.
