Which NMEA2000 gateway to use on a VP 4.3 GXi-E
Katlin101010
I have twin 2005 Volvo Penta 4.3L GXi-E engines (port SN: 4012037869). I'd like to set up a gateway to view my engine paramenters on my fishfinder control head.
Which one should I get? Does each engine need it's own unit? Where does the unit get connected on the engine?
Thanks for any info
alldodge
Welcome
Your serial number (tanks for providing) list part number 3858888 which is a MEFI but unsure if it's a 3 or 4 model. Either way you will need a gateway connection to use.
MEFI's are not great with providing much data and if the gateway's that are available work, I'm unsure. Suggest contacting a place like Fox Marine and see what they can offer. Never done business with them, just found them searching
Katlin101010
The number (the part number I think) on the sticker on engines is 3869252. Is this an MEFI engine as well? IMG_5417.jpeg
alldodge
SN 4012137867
Using this serial number it comes up with more detailed info. ECM part number 3863326
Volvo
Gateway
Kosmofreeze
Welcome
... Suggest contacting a place like Fox Marine and see what they can offer. Never done business with them, just found them searching
^^^^ THIS ^^^^
I have a 2001 5.7GXi-A. Contacted Fox Marine and they knew exactly what I needed. Easy install. Works Great. Turned an old cruiser into my "Glass Cockpit" pride and joy.
4now04
My guess is that your engine uses a MEFI 4. My 2002 Volvo 5.7Gi-B also uses a MEFI-4. You can remove the 2 or 3 mounting screws and look at the label on the back of the unit. It will say which MEFI version it is. I have also been looking at the Fox-Marine unit, but haven't done it yet. If you go that way and connect to your graph/chartplotter, also download the app from Fox-Marine for your tablet, smart phone, or laptop so you can see much more info through a bluetooth connection than is shown on your dash-mounted electronics.
