Seized Lower Shift Cable Nut
johnkom
Need some ideas. When I started to remove the lower shift cable nut on my MC-1 outdrive the nut facets rounded over. So I drilled the center out and used some heat on the casting. No luck. The nut split. I'm stumped. Any ideas? Really hard to get into the cavity to work.
Scott06
Take it off ( bellhousing) if you can do the work great otherwise Take it to a machine shop. Use an end mill to cut it flush, drill out and retap it.
johnkom
Thanks nola mike. Interesting tool. Wish I had it yesterday. But I finally got it out. I used a punch to fracture the nut. I was then able to run the straight tap though the housing.
