Black scuff marks on cylinder walls
SSG Retired
Use a factory replacement gasket.---Best quality
I have a question about the oring that sits at the top of the driveshaft. Mine currently doesn’t have one on it. When I replaced the water pump last year it also didn’t have one when I pulled the lower unit. My manual says to install oring on the upper drive shaft but I can’t find an oring on any diagram for my engine. So I’m confused about whether or not I need an oring on the drive shaft. Could you possibly help me answer that? And if so, would you happen to know the part number if I do need that gasket? Thanks again!
SSG Retired
There is definitely a spot for one on the driveshaft. But there’s also a big oring inside the crankshaft head cover. So does that seal the driveshaft or does it need an oring added on the driveshaft as well?
jimmbo
It does look like the Bottom Crankcase Seal has seen better Days.
However, knowing which engine this is, will make it easy to find the correct Parts Listing, which will reveal if it has an O-ring on the Driveshaft.
SSG Retired
It’s a 1994 Johnson 90hp v4. Model number J90TLERC. I have looked at multiple diagrams and cannot seem to figure out if it’s suppose to have an oring below the splines.
I am replacing the bottom crankcase seal and the oring that sits inside the sleep that goes at the end of crankshaft that sits under the crankshaft head
jimmbo
Looking at the Parts Diagram for that Model # doesn't show an O-ring on the Driveshaft.
Put some Grease on the Splines, but make sure there is None on the Top of the Driveshaft, or Bad Things will happen. Do Not put any grease on the Splines in the Crankshaft, as that too can cause Bad Things. Wash them out with Brake Clean
SSG Retired
Thank you so much!
jimmbo
Going back in the yrs, it appears that 1991 was the last yr there was an O-ring at the top of the Driveshaft.
There would be an O-ring included in the Water Pump Kit, if the Kit was covering a large number of years.
SSG Retired
So I’m assuming the big thick black one inside the crankshaft head seal is what stops water from from back up into the motor and keep oil from leaking out. That and the seal
SSG Retired
Do you know what these little pin holes are? Looks like corrosion or something. The pits aren’t too deep but there’s quite a few of them
Mc Tool
They are bubbles in the ally casting that have been exposed by the machining and as said above dont worry about them ............and dont think about all the big ones you cant see😈 😂😂
Little bubbles are not troubles ----On these wonderfully simple motors.
jimmbo
Heat can cause Cracks, but those Bubbles were formed when the Aluminium was Molten
SSG Retired
Good to know. It scared the crap out of me. I really do appreciate everyone’s advice and input. It’s helped me tremendously while working on this motor. Thanks again!
