Scott06
- Apr 20, 2014
- 7,620
michigan vortex has them in 15"@Scott Danforth What prop brand/model did you run on your 15P 3 blade? All I can seem to find in a 14-1/2" diameter 15P 3 blade (and 4-3/4" gearcase) are some older Vengeance/Silverado SS props. I was hoping to find some aluminum props (due to lower cost, but also making the prop the sacrificial component on debris strikes) in this dimension, but can't seem to locate. Separately, I decided to order the reasonably priced 14-1/2" 19P 3 blade Black Diamond that I linked on post #27; which I'm guessing will be my "unloaded/high speed prop".
Michigan Vortex 3-Blade Prop, Exchangeable Hub / Aluminum, 15.25 dia x 15, RH
Vortex is a high performance aluminum propeller that utilizes the XHS Xchangeable hub system.
here is a merc black max
Mercury Black Max 15.25x 15P Propeller 48-78116CP1
Shop Wholesale Marine for Mercury Black Max 15.25x 15P Propeller 48-78116CP1. Wholesale Marine offers one of the largest selection of boat propellers at low prices and same day shipping.
