Losing power on 2000 2 stroke Johnson 70hp
Collinsonbailey
The motor runs fine on muffs under no load. When put in water it will run until full throttle then it will loose power and drop revs. I have just cleaned all carbys. Replaced spark plugs. Have checked ignition coils and lead. Wondering what else it could be or if anyone has any ideas on what to check.
Pump primer bulb at high speed and see if she will keep running. If so, it is likely a fuel pump or fuel line issue. My SeaRay I/O did that and it turned out to be a partially clogged filter on the fuel pickup.
Collinsonbailey
Yes have tried that and it doesn’t seem to make a difference.
They all run great on muffs.---Even in gear it is still neutral , as the prop does no work.-----Post the actual results of a compression test.-----Have you checked water pump impeller / thermostat??----Could be overheating going into S.L.O.W mode.
Is there a filter between the primer bulb and the carbs? Is it clean?
