Mercury thunderbolt 500
Status
Not open for further replies.
Dionw
The Key that connects the Impeller
I can't find the woodruff key hole for the key, there's a slot for a wrench but no slot. I'm going to try and put back together and check all the vitals, spark, compression, fuel... is this the fuel pump in the photo?
jimmbo
There is no hole. The Key in this case, fills the Void in the Driveshaft
Dionw
Ahhh ok, thank you for that. Just letting everyone know I'm mo mechanic but have an idea of how stuff works, I worked on a few dirt bikes and some early model cars. Thank you for all your advice guys
Remove the 2 narrow covers above the fuel pump in the picture.----Allows you to look at pistons / rings.
Dionw
Will do thank you, will put up dates, in the mean time I'm still looking for a manual in nz
THEHIGHAMS
Hi team, just an update, pulled bottom leg off and there's no housing or impeller, I am feeling this was a parts motor and wasn't advertised as that. Oh well I can now try for spark and compression etc as I have freed up the gear selector as it wasn't even in the sleeve.
Nordin
Agree with you Jimmbo, those red and blue decals from 1968 to 1975 are the best looking Mercurys. Have three of them myself, 1970 500 Thunderbolt, 1971 800 Thunderbolt and 1972 800 Thunderbolt.
All with distributer ignition system.
1960 Starflite
My 1975, 850 w/electronic distributor sure starts well. A lot easier than my 300 and 650 with magnetos.
Gee, I always thought the 850s like the '73 I had ran well, were easy to tune, mount and had good power for the weight. The insulation on the engine harness and dissy wires failed, after a few decades. The ign components were pricey as well.
Status
