Yamaha f40bet overheating
chookstar
Im hoping you can help me with my problem as i have run out of ideas. I have a Yamaha 40 HP 4 stroke outboard F40Bet I was cruzing along mid speed after a few minutes the temperature buzzer sounded, with cool water coming out very well from the tale tail and at a strong pressure. I checked thermostat but it has been removed by previous owner. Still after 4 minutes on idle the temperature buzzer would beep. I have removed and cleaned the exhaust plate, changed the impeller. Switched on the engine and still on idle after around 5 minutes the temperature buzzer went off. I am honestly out of ideas and desperate to find a solution. Engine is really getting hot especially around the thermostat area. I also tried changing the temperature sensor with a new one but still no change. When i switch on the motor without the thermostat cover water flows out. Any ideas what could be wrong? really appreciate your feedback.
99yam40
you might try using a chemical descaler like Rydlime marine descaler.
or take the motor apart farther to find what is plugged up
Could be corrosion issues / blown head gasket.----Post actual results of a compression test.
cyclops222
I once had 2 brand new thermostats AND 2 new thermostat gaskets.
Sadly The gaskets were new rejects. The gaskets would get pushed up at a angle and jam the thermostat at a partially open position.
Plugs blackened & started missing in a few hours. I removed the rubber gasket and it ran almost perfect for a month everyday.
chookstar
Ok cheers I will have a check
