Scott06
- Apr 20, 2014
- 7,359
Yep needs to be glued firm in place contact cement or bellows adhesive let it set up over nightIt needs to be really glued in place with some 3M or similar adhesive. Leave it set for some time. Use a new gasket and water passage “O“ ring.
Support the drive so that you do not have to hold it up to install it. Without support you run the risk of dragging the large seal ring into the bellows and water will again enter it.
