What reason causes the water leaking into gimbal bearing house?
liusigou
My boat engine is Mercruiser alpha one gen 1, 1989,120HP,2.0L. Last time I found some water leaking into gimbal bearing house. After I did the seal of gimbal bearing bellow and exhaust bellow and lower shift cable. In the past 2 weeks it run faster at the beginning into water, after 8 hous' in the water and it run slow and there was some noise from outdriv. Today I took the outdrive off and found that some water still leaks into gimbal bearing house. How can I identify the leaking reason? Should I completely do the bellows sealing again?
See the attached file
kenny nunez
Have you pressure tested the outdrive? Is there water in the drive? When the drive was installed was the large rubber ring glued in place?
liusigou
I cannot remember when I did the pressure testing. But the gear oil is good and is not milky. I did not see the large rubber ring. Could you please upload some pics for the large rubber ring?
tank1949
There is a housing seal that prohibits water from entering through coupler spline. Few replace them but you have an older boat that may need a new one. Water spray may be dripping down into cavity. You can buy a pressure testing tool. I suggest investing instead of throwing parts after parts. Good luck
Scott06
That seal is to keep gimbal bearing grease out of the bilge not bilge water out as there is a small bellows drain hole in transom. This seal is not used with newer permalube bearings.
Bilge water if very over full can get water in bellows. To the OP it doesn't look like the gasket (Quad ring) is in there - this needs to be glued in place before drive is installed and comes with drive gasket. You may have water coming up the shift swivel shaft in the bellhousing into this area and if quad ring gasket is not there it can enter bellows.
liusigou
it seems that my big rubber O-ring was never installed. I will put it back
flashback
may want to get a new gimbal bearing or you'll be in there again soon.
liusigou
Is it possible that water leaks from the shift cable area? Also Can I reuse the gasket after I apply some silicom?
tank1949
My old Alpha1 leaked there. Seal was crap. I replaced and never had an issue. Just saying...
Scott06
More likely the seal in the shift shaft in the first pic. There is a seal below the top lever. unless the cable is leaking probably not the cable side
Either way the quad ring will keep it out of bellows
Scott06
that may be , not sure how the water flow is occurring in your scenario? can you describe
the part is called an oil seal
1721758892756.pngthe video below references the service bulletin about 9 min mark that states grease seal is not needed using the non greaseable bearing, and it is not installed in later gimbal housings from factory.
liusigou
Can Scott help me identify what parts were missing for the shift shaft? I am cencerned water leaking from it?
Scott06
liusigou
Hi Scott, Can the big rubber o-ring prevent water leaking into gimbal bearing house if the drive gasket is good and the bellow works? if so I will do a testing tomorrow.
Scott06
Hi Alldodge and Scott, Can the big rubber o-ring prevent water leaking into gimbal bearing house if the outdrive gasket is good and the bellow works? if so I will do a testing tomorrow.
I believe that is what it is there for
tank1949
View attachment 400820the video below references the service bulletin about 9 min mark that states grease seal is not needed using the non greaseable bearing, and it is not installed in later gimbal housings from factory.
My old Sea Ray was a wet deck boat and I'd get lots of spray. Spray would leak down between motor hatches and transom. I even had it short out a coil. I added a shield to eliminate the short and then noticed how gravity made the spray drip on coupler shaft. I pulled OD and could see daylight around old seal. No seal lip tension at all.
kenny nunez
It needs to be really glued in place with some 3M or similar adhesive. Leave it set for some time. Use a new gasket and water passage “O“ ring.
Support the drive so that you do not have to hold it up to install it. Without support you run the risk of dragging the large seal ring into the bellows and water will again enter it.
