saltchuckmatt
- Jul 19, 2019
- 3,348
Carb, carb, carbs. When they don't idle correctly the carbs usually are to blame.
well if you can move it it slipped! found the issue. you can also see the glue is cracked. i dont think that white mark is a reliable way to re-set the magnet. i just grab another flywheel.Thanks for your replies. Racerone, I've now got the picture I think you needed. It shows the notch in the inner (ring) magnet in relation to the manufacturer's mark on the flywheel. Am I right to think they should line up.? If so, then my ring magnet has slipped. I can move it a bit by hand.
