Alpha one gen one drive rotation?
banderberg
Reading the manual for the stern drive shift cable adjustment and it has two methods one for right hand rotation drive and one for left. What is the Alpha one gen one?
Bt Doctur
All Alpha 1 and Alpha GEN II are clockwise in fwd gear. Alpha 1drives were never counter rotation
With the new style cables you install, adjust , and insert cotter pin.
banderberg
So I should follow the right hand rotation instructions, correct?
banderberg
Ah, I just found there's a section below the shift adjustment that explains how to tell RH from LH. Problem solved.
