- Jul 18, 2011
- 19,611
. . . the hits just keep on coming . . .
I've been doing a bunch of work on my boat and engines . . . mostly of the electrical nature.
Anyway, I am getting low voltage warnings on the starboard engine. Once the engine starts the warning goes away and the VesselVeiw says "OK".
I then noticed that when I turn the engine battery switch off, the master relay starts buzzing (engine off of course). If I turn the the battery switch back on - the buzzing stops.
I swapped out the relay and it made no difference. (The new one buzzes too)
To hopefully see more info, I hooked up my Diacom and recorded some data.
First is the starboard engine:
Not running
Running
Here is the Port engine, which looks fine
Not running
Running
I believe the voltage titles in the Diacom might be incorrect and should be swapped. Anyway the key symptoms are low system voltage on Starboard engine prior to starting, and more normal voltage while running, then buzzing of the relay when the battery switch is turned off.
Port engine looks/acts fine.
I am just wondering what is dragging down the voltage on the starboard engine while it is off. Here is the summary of what I have found . . .
Recent work done on starboard engine/electrical ( I know it is always the last thing you did/touched
) (maybe)
- New alternator
- Cleaned up a few of the power connections on the starboard positive isolation post.
This one might be something for @Fun Times and @muc to take a look at . . .
T.I.A as always.
Not running
Running
Not running
Running
- New alternator
T.I.A as always.
