- Jul 18, 2011
- 19,422
The solar controller does that. It reduces its output as needed . . . basically creating resistance. The problem is that the solar strength varies, as clouds pass by, so it is constantly varying its output. But the solar controller attempts to go through the bulk, absorption, and float stages of charging.Question
A Bat charger reduces the amount of Amps as the need for charge is decreased. The solar charger outputs X amount and is dependent on the sun. What regulates the excess power not needed, and where does it go?
To really get bulk charging, you need a good amount of solar panel to get the amperage at the voltage. My system does not have a lot of power vs. the battery capacity.
This system differs from my prior system in that the MPPT controller 'squeezes' the output as needed to maximize the power output. So, you get situations where the current is held low, which forces the voltage high. My previous solar controller was PWM (pulse width modulation), It attempted to regulate the voltage, but not maximize the power.
